-   -   Dt466e alternator removal. (https://www.skoolie.net/forums/f13/dt466e-alternator-removal-26196.html)
Dead pirate 03-15-2019 07:17 PM
The pivot bolt that the alternator rests on is stuck. It won't rotate and won't pound out. Heat and pb blaster does nothing. Confused as to why it don't come out. Any ideas?
cadillackid 03-15-2019 07:26 PM
if you remove the other brackets around the alternator will the whole alternator and bolt spin as one? im assuming you cant get an impact in there to bang on it?
Johnny Mullet 03-15-2019 07:55 PM
The bolt is stuck in the steel sleeve or most likely the aluminum parts of the alternator. Find out what part it's stuck in and use some heat on the stuck section with a hand torch.
Dead pirate 03-15-2019 09:40 PM
I can remove the bracket below it (along with it) but that bolt will still be stuck. It's probably frozen in the sleeve. Or something. I've had a torch on it. 6' bar....5 lb. Sledge from behind.
Hope it doesn't go out anytime soon. Most likely leave it in. I like my 360 alternator.
cadillackid 03-16-2019 08:02 AM
If you don’t have to yank it then id keep hitting it with PB every day or two.. that stuff works on over time, esp with heating and cooling like it will see when being driven.
Hristopher
Dead pirate 03-16-2019 12:46 PM
Right on. That's what I'll do then. I can change it when i want.
magnakansas 03-16-2019 01:15 PM
escalate the attack
Well, if the alternator is broken, then you cant break it. Right?
heat to the point the steel is glowing orange, drown the thing in penetrating oil. In the end you can cut the alternator off then work on the bolt.
Would you post some really up close pictures of the pivot bolt... and both ends of the bolt, especially then with the threads. Is the bolt going though a sleeve?
william
Dead pirate 03-16-2019 01:27 PM
I'm at a kid birthday party. I will post tonight.
Dead pirate 03-16-2019 07:03 PM
4 Attachment(s)
The bolt in question. The alternator pivots freely on that very bolt. Attachment 30797Attachment 30798Attachment 30799Attachment 30800
