-   -   bus aerodynamics (https://www.skoolie.net/forums/f13/bus-aerodynamics-26354.html)
pengyou 03-29-2019 02:17 AM
Originally Posted by Sleddgracer (Post 316564)
I just spent too much of my day reading about improving aerodynamics ( thankfully it's been a slow day here at the kennels ) - sites about improving a semi's mileage, a couple of old skoolie threads about the subject of improving air resistance on buses - I'm planning on a roof raise and that will give me the opportunity to alter the profile of the roof line, rounding off both front and back, at no or little extra cost ( labour not taken into account ) -using conveyor belting to make a front air dam, side skirts, and an abbreviated tail to reduce wind turbulence at the back, will make quite a difference - belting can be low to the ground for maximum effect and is flexible if more ground clearance is needed - I'm pretty sure I can get all the belting I need for a case of beer - so the cost of going for some aerodynamic improvements will be small and going by the improvements in mileage I achieved with a simple scoop on the awkward load I mentioned before, I think a 10% improvement is reachable - with the $6.40 we are paying here for an Imperial gal of cheap gas, that 10%, or even less of an improvement, will make quite a difference on a 2000 or 3000 mile trip - if it's only 10%, I'll could save $240 on one 3000 mile trip
What is belting?
Sleddgracer 03-29-2019 11:19 AM
Originally Posted by pengyou (Post 316828)
What is belting?
conveyor belting
pengyou 03-29-2019 05:44 PM
Originally Posted by Sleddgracer (Post 316851)
conveyor belting
Which is.....??
Sleddgracer 03-29-2019 05:48 PM
Originally Posted by pengyou (Post 316916)
Which is.....??
rubber belting used on conveyors
https://www.google.com/url?sa=i&sour...53982448537262
o1marc 03-29-2019 05:49 PM
1 Attachment(s)
Which is.....??
You've never seen a conveyor belt before? The belts are repurposed when worn out or broken. An appropriate size piece can be used for airdam and skirts. Sort of like mudflap material.
pengyou 03-29-2019 07:10 PM
Thanks! Yes, I have...but was not aware that it could be repurposed to use on a skoolie!
Sleddgracer 03-29-2019 09:21 PM
with skoolies we get to do it our way - many of us are on a tight budget, so costs are important too - for safety's sake, what we do has to be safe and legal - for something like air dams that for best effect, have to be low to the ground, I can't really think off hand of anything more suitable than rubber belting - if you hit a rock or curb with it,it will bend and fall back into place - as long as it's well fastened at the top, no damage done unless the paint job needs a bit of a touch up - 3 or 4 ply belting is amply stiff enough to deflect air -using custom air dams could easily run into $1000's and rubber belting is cheap, or if you know the right people in the right places, it can be free
