-   -   Doing the unthinkable to the high-top? (https://www.skoolie.net/forums/f27/doing-the-unthinkable-to-the-high-top-29513.html)
LoveBusTreatery 11-26-2019 05:37 PM
3 Attachment(s)
Hey all.
So I'm curious if anyone has more experience with fiberglass high tops than I do? I want to cut into mine, the same time I do my fan install, to maximize the headspace available. I just want to cut HALFWAY into the support beams where the dotted lines are around the fan, and I would screw in wood supports all around the rectangle where the blue lines are. I'd be taping the fiberglass to minimize splittage, and cutting long strips on a diagonal out of the support beams from the hole where the fan goes on both sides, but not actually cutting through the roof other than the solid red lines. I included a rough idea of how the cuts would be positioned, but it's not a great image as it's hard to find pictures of a high-top sawed in half. Can I or should I blow it with fiberglass or caulk it with something special after I make the cuts? Should I screw the support beams around the cut area before I begin to help support the temporary weakening?
Is this going to totally compromise my roof? Why or why not? Do you have a better idea? (Please don't suggest 'buy a different van' - this is a non-starter. I'm a creative problem solver, not a start-overer.)
Secondarily curious if anyone has tried putting a solar panel on a tilt mount on a fiberglass top - it's quite curved in the middle so would teeter-totter well! :rofl:
:Thanx:
LoveBusTreatery 01-17-2020 09:02 AM
#beendone
3 Attachment(s)
Sorry for the delay guys, I've been -1 computer for a few months now. Here's the update, it went down really well and I'm super happy with how it turned out.
Get creative, that's what it's all about. Now I have perfect amount of headroom for myself to stand while cooking, dressing, even enough room to do (no hands over my head) yoga!
