-   International | Navistar Drivetrain (https://www.skoolie.net/forums/f37/)
-   -   Engine warning light (https://www.skoolie.net/forums/f37/engine-warning-light-30009.html)
HappyInTN 01-13-2020 08:37 PM
After letting the glue plugs warm then starting the engine. The engine warn light stays on for about 1-2 minutes then goes out. It never used to stay on after the system check. Thoughts? 2000 AmTran Genesis FE dt466
dmattarn 01-13-2020 10:07 PM
Your 466 has glow plugs?
Maybe t444? Either way it could be a sticking glow plug relay. If you have the means to get a scanner on it while the warn engine light is on it should tell you.
