-   Cummins Drivetrain (https://www.skoolie.net/forums/f39/)
-   -   95 Ford B800 - Where is the fuel system solenoid relay? (https://www.skoolie.net/forums/f39/95-ford-b800-where-is-the-fuel-system-solenoid-relay-31629.html)
mudspringer 06-10-2020 07:34 PM
I have a 1995 Carpenter School Bus on a B800 chassis with a 12 V Cummins 5.9 Diesel. The engine will not start unless I use a zip-tie to hold open the fuel shutoff solenoid. I have determined that no electricity is getting to the solenoid when the ignition is on. If I jump the pull pin, the solenoid kicks in. If I push the solenoid by hand and energize the other pin, the solenoid stays up.
I'm trying to locate the relay that feeds the solenoid. I found what I thought was the relay, but I'm not sure if it's the same one. When I jump this relay, the buzzer and bell that normally sound when I turn on the ignition start sounding, but the fuel solenoid does not engage. I'm also not seeing any continuity between this connector and the one on the solenoid - so I'm not sure if this is the same as the fuel shut off relay or a different one..but I can't find any other relay anywhere - so I'm confused.
1) Is this the fuel system shut off relay or a different one?
2) If this is the correct relay - why is my test not working - am I missing something obvious?
3) If this is not the same relay, does anyone know where I could locate it? I've looked on the firewall, under the bus and under the instrument panel.
Thanks -
- Jon
