-   -   RE road dirt in bedroom (https://www.skoolie.net/forums/f13/re-road-dirt-in-bedroom-31818.html)
beachtomountains 06-25-2020 09:09 PM
1 Attachment(s)
So I have a Gillig transit RE. While removing the rear flooring and wall carpet(?) a TON of road dirt came down with it. It was in every crevice. Only in the back, where my bedroom will be. The only opening back there is the vent (intake?). If I could figure out how to open the vent (it has hinges so I know it opens) I could rig up a filter maybe? Does anyone else have a similar setup and have you have issues with road dirt inside?
Native 06-26-2020 01:09 AM
I wonder how much of that road dirt is simply dirt and dust sucked through the windows and service door and off of passenger feet/clothes during normal operation. The air vent will draw air from the inside of the bus and with it all the particles in the air. It makes the inside of the bus and in particular the back end a huge air filter.
beachtomountains 06-26-2020 01:15 AM
I wondered that myself but itís very very fine gray dust. It matches perfectly with the road dust thatís also built up in the battery compartment underneath and a few other places under or outside. The middle and front of the bus on the inside donít have any of this stuff anywhere. Itís definitely asphalt, not natural dirt.
Native 06-26-2020 02:41 AM
Then I would suspect a hole somewhere forward of the vent.
Is there any pattern to the dust distribution? This may provide clues as to the source.
Meathead 06-26-2020 08:56 AM
1 Attachment(s)
Yeah. I had that. But mine is school bus. The rear lights didnít leak water but somehow dirt was forced in from underneath. I deleted the lights and foamed everything back there. Attachment 45999
When I drive down a dirt road you wouldnít believe how much dust is kicked up from the radiator fan. Then you have your exhaust. And since your rig has the aerodynamics of a brick, the turbulent air back there is amazing. You have a small hole/crack somewhere. Maybe spray that back wall w that stuff that you can make a boat out of a screen door. [emoji54][emoji2]
