-   -   Tire Options (https://www.skoolie.net/forums/f13/tire-options-33879.html)
Joe45 11-25-2020 09:12 PM
Tire Options
Just wondering...
Are there aggressive tires for skoolies, like an all terrain?
How about putting on the larger military tires?
Is it feasible to convert the rear dualies into single tires like the above, or the ones I see on big rigs (Super Singles)? I imagine they are probably very expensive.
Just thinking.
dzl_ 11-26-2020 02:13 AM
Originally Posted by Joe45 (Post 415390)
Just wondering...
Just thinking.
Yes usually they are marketed towards construction or mining/logging for the more aggressive types. In the ballpark of an all terrain to mud terrain. Usually a lower top speed though.
dzl_ 11-26-2020 02:28 AM
Skoolie tires are largely interchangeable with big rig and other commercial vehicle tires so there is a good amount of selection including more aggressive treads if you have a common size.
Brad_SwiftFur 11-26-2020 08:19 AM
And yes, you can convert the rear tires to the wide "super singles" ... at no small cost. Tires are about double the cost of the regular tires, but you only need two instead of four.
Pros - they look cool, save weight.
Cons - if you blow a tire, you're not going anywhere. Rims usually get trashed when this happens. Inability to swap tires for a "spare". Not all shops keep these tires in stock if you need road service.
Joe45 11-26-2020 04:17 PM
After reading about the super singles, I think I'll stay with the regular ones.
I'm going to check out some of those industrial tires.
By lower top speed, what do you mean? I can't imagine wanting to do more than around 60-65 in a bus.
Brad_SwiftFur 11-26-2020 05:17 PM
Some commercial tires such as those intended for log trucks are marked for a 55 MPH top speed. It's probably not due to the belts or sidewall construction, but the deep tread might "squirrel" about under a heavy load at high speeds, causing unexpected handling for a driver not expecting it.
Then again, I could be wrong. Anyway, just look for some suitable drive tires which you should be able to find easily enough.
Mekanic 11-26-2020 07:53 PM
If it happens you might just flop on your side. This is why NO ONE puts super singles on single axles trucks. ONLY used on tandem truck and tandem trailers.
Joe45 11-26-2020 08:03 PM
GREAT POINTS!
Thanks!
rossvtaylor 11-28-2020 10:28 PM
If you can find them, the Dynacargo Y601 tires are a good compromise between highway suitability (and good load capacity) and off-road use. We put them on a Freighliner "expedition" rig conversion and have been super happy with them. I actually went looking for more, recently, but it seems they're out of stock in all the usual places...maybe because they're Chinese imports? Who knows...but I highly recommend them.
Joe45 11-29-2020 10:40 PM
Thanks.
Will look into that.
The Wandering Dragon 01-05-2021 07:08 PM
Im Still Working On My Bus, But I Do Have A Question, About The Super Single Tires..
I'd Like To To Place Them In The Front, Like A Dump Truck Or Crane Truck.
Wondering If Anyone Has Done This, And What Kinda Clearance Issues Did You Have In Fitting The Tire?
s2mikon 01-05-2021 07:41 PM
Wandering dragon. Tell us why you want to do this. Do you have a weight problem on the front axle? Or just looks.
rossvtaylor 01-05-2021 09:06 PM
They might work...if you never planned to turn the steering wheel! Super singles take the place of dually tires in the back and are, essentially as wide as two tires with a gap. If you put those on the front, you'd have serious interference issues. And, of course, you couldn't legally do that anyway. Those are drive tires, not steer, so they can't be put on the front...and shouldn't.
We did bump up tire size on a Freightliner ambulance conversion, to the Y601 DynaCargos I mentioned above. That required new rims which are wider...I think 9 inches...and some minor lift. It looks awesome and adds some ground clearance. Those are all position tires and they've been off road and 1000s of miles on the highway. They are speed rated to 85 mph, if I remember right...or at least to highway cruise speeds. But that's as "aggressive" as I'd dare on a bus or other big vehicle.
rossvtaylor 01-05-2021 09:11 PM
1 Attachment(s)
Here's what that looks like, by the way...
Attachment 52707
Booyah45828 01-05-2021 09:32 PM
Like others have asked, why? Those dump trucks and cement trucks run the wide fronts because the want the surface area to not get stuck in soft soils. That, and they can load more weight with them, but they typically have an axle that will support the additional weight.
Your bus axle doesn't, so the extra weight capacity of the wide tires won't be utilized because of the axle limits.
The Wandering Dragon 01-14-2021 04:19 PM
Looks And I Was Hopin For Better Handing...
I Have A Car Going In The Back Of The Bus, But I Have A Ton Tag Axle Added In So Back Weight Is Not A Problem..
Danjo 01-14-2021 05:11 PM
1 Attachment(s)
I need new tires too. I knewI would need new ones soon, but I found myself stupidly trying to clear this muddy hill in the dark. I found myself up on a berm after try 4 because I wasn’t able to see how I was backing. But there you go, muddy hill, bald tires and obstinate stupidity got me stuck. I had to dig out the next morning and have my buddy yank me out with a chain after airing up the drivers rear tires. Seems I was running on a flat inboard tire.
So I too am looking for AT’s. I want to be able to keep a 75 MPH top speed if I can. Any recommendations (aside from the obvious one of not being a knucklehead)?
Ronnie 01-14-2021 07:41 PM
I like the BF Goodrich all terrains. Should be good for a shorty with 16" wheels. Have used them for years on my pickups. Not real good in deep mud, but great for all other stuff and snow.
s2mikon 01-14-2021 08:09 PM
I'll second the BF Goodrich all terrains. Been running them for decades. But I think I'll be switching to cooper's next time. BF Goodrich has discontinued the tri guard sidewalls. You might want to think about a locking differential in a unit like that with the heavy rear end they will pull you through. When I had the shop my wrecker and service truck both had them and it made all the difference in the world.
Ronnie 01-14-2021 09:09 PM
Locking diffs are nice, have one in my bus, and my pickups I have had at least a limited slip or locker in them .
