-   Heating, Cooling and Appliances (https://www.skoolie.net/forums/f51/)
-   -   Mounting and running mini split AC units (https://www.skoolie.net/forums/f51/mounting-and-running-mini-split-ac-units-37731.html)
bridg73988 10-16-2021 12:29 PM
Just a couple quick questions about mini split AC units.
1 - Did you mount the outside unit firm, with rubber mounts, or on a floating base suspended by springs?
2- Did you run the copper line all the way to the outside unit or did you stop the copper along the bus frame/body and finish it out to the unit with rubber AC line for flexibility so the copper would not work harden and crack?
3 - Do you run your mini split while driving or only when parked? Seems like the constant bouncing would not be good on a unit while running.
Josaso 10-23-2021 04:28 PM
Idk much myself but I read on here that bumping could hurt the condenser. And usually you will need a lot more btu’s while driving so that also makes it not worth it.
