-   International | Navistar Drivetrain (https://www.skoolie.net/forums/f37/)
-   -   1995 International 3800 - carrier bearing and rear suspension leak (https://www.skoolie.net/forums/f37/1995-international-3800-carrier-bearing-and-rear-suspension-leak-37809.html)
Bear Gerschafer 10-26-2021 04:08 PM
Skoolie Fam!
Our bus is in the shop for one last oil change and inspection before we take-off, and the mechanic noted play in the carrier bearing, and a leak in the rear suspension.
They said neither one is an emergency situation, that I can drive it for now, but should think about replacing before or during my next service. They are looking up ETA on parts, just incase I want to pull the trigger now, but she did mention parts are hard to get right now.
My question: are either of these an easy DIY job? Carrier bearing looks easy enough to find, and fairly inexpensive - just not sure I have the mechanical chops to pull it off without many hours of youtube education ;)
For the rear suspension - the 2 air bags in back look almost brand new and I haven't had a chance to get under there with the soapy water to check for leaks.
Are either of these emergency problems that I should fix before we hit the road? Or could they be handled along the journey? (We will be in Iowa for a few weeks and I could possibly plan a head with a shop to get the service done there. . . or anywhere along our route for that matter)
any input or advice is much appreciated, and thank you all of your help so far :Thanx:
Bear Gerschafer 10-26-2021 06:32 PM
Quick follow up - the shop (W.W. Williams) called with some quotes, and confirmation they can get the parts delivered within a day or two if needed. If/when we go for the repairs we can probably get the bus back within 3 or 4 days.
Rear shocks (leaking) - $520
Carrier Bearing (loose, play in the bearing) - $630
All prices pre-tax and disposal fees.
Full oil change with filters came in at $575, not too bad for 30qts I think?
I'll pick the bus back up this afternoon and will probaby take it to another shop just to get a second opinion (we like our due diligence).
Still interested in any of the wizards' opinions on these parts, repairs, and how important / urgent the repairs may be :)
Thanks y'all!
