-   -   Putter's Bus (https://www.skoolie.net/forums/f27/putters-bus-4561.html)
putterspitt 11-01-2009 04:58 PM
Putter's Bus
Finally got around to taking pics after injector pump and injectors were installed. My father-in-law is great to have around, can help fix anything.
89 Thomas 7.3 diesel Room behind drivers seat is 7'6" by 15'6". Going to be fun laying it out. I do like the Cockabus layout, been looking at it since I joined.
All suggestions are appreciated and welcomed. Putter out
putterspitt 11-01-2009 05:05 PM
Re: Putter's Bus
How do you attach pics if the file is too big? anybody tks
putterspitt 11-01-2009 07:54 PM
Re: Putter's Bus
Pics are on page 11 in the photo gallery, I will post others there as they are taken, tks Smitty
putterspitt 11-16-2009 11:51 PM
Re: Putter's Bus
Has anybody here in the forums had any problems with people while traveling looking backwards in the bus at a tv or entertainment center?
I know some people get car sick and such. Thinking of putting cabinet at rear of bus with tv,stero,speakers, and some storage. Also putting battery bank and inverter below as it can be gotten to inside or by opening the rear door. Generator will be located on a rear deck or underneath. Keeps alot of wiring to a minimum. Cabinet will go from side to side.
putterspitt 11-17-2009 10:31 AM
Re: Putter's Bus
Smitty, thats the bus I am talking about, its mine....lol
The chimney is attached to the house though. Just trying to get the most oout of the space
putterspitt 11-17-2009 12:31 PM
Re: Putter's Bus
it would look good with a flamethrower in the front though like jacuzzi bus
putterspitt 11-17-2009 12:34 PM
Re: Putter's Bus
1 Attachment(s)
the other side
snitty how did you get the pic larger than mine in the post? tks
putterspitt 11-17-2009 01:19 PM
Re: Putter's Bus
tks Smitty
putterspitt 11-17-2009 01:31 PM
Re: Putter's Bus
1 Attachment(s)
try this again
thanks again Smitty you da man
Abbott 11-18-2009 11:01 PM
Re: Putter's Bus
Neat bus. I would cut the top off of it and jack it up about a foot :) I think a bus that size would make for a very useful conversion.
putterspitt 12-06-2009 03:50 PM
Re: Putter's Bus
Is there really a need to keep the 2 support poles in the entry way of the bus? I have seen pics both ways, opinions anyone?
paul iossi 12-06-2009 06:30 PM
Re: Putter's Bus
you only need one pole for every 3 dancers/strippers :shock: , actually they are for handholds/supports for the passengers and not structurally required.
putterspitt 12-06-2009 08:04 PM
Re: Putter's Bus
it will be a 3 minimum stripper bus
putterspitt 12-07-2009 04:30 PM
Re: Putter's Bus
1 Attachment(s)
here is the converter hope it will charge 2 batteries
bikeforthelight 12-07-2009 08:02 PM
Re: Putter's Bus
It should work great for you. what amp rating is it?
Diesel Dan 12-07-2009 08:40 PM
Re: Putter's Bus
I've been thinking of leaving the pole on the passenger side, but not the driver's side. I feel like if someone walks up to the front while you're on the road, they should have something to hang on to. I may even leave both in if they are not in the way. But at least one will probably remain. Depends on how my floorplan pans out.
putterspitt 12-07-2009 09:06 PM
Re: Putter's Bus
I want to put in a captains chair for a drivers seat so I need at least the drivers side to be out of the way.
putterspitt 12-07-2009 10:59 PM
Re: Putter's Bus
1 Attachment(s)
this is the best I can do for now I think its a good concept
S= STORAGE need that stuff for tailgateing tables chairs
C= CABINTS
X= SEATS bench type with a table that will lay in for a bed
fridge 5' will be behind driver
putterspitt 12-08-2009 04:01 PM
Re: Putter's Bus
good ole bigguns and big ole gooduns
putterspitt 01-22-2010 12:03 AM
Re: Putter's Bus
I need a little advice. I am going to use this bus for the races and a few games. Is it worth the expense of taking side panels off and insulating or not.Will have a rooftop a/c, so I want to keep it cool or warm. Getting ready for some interior work as it rains every few days right now. Wish me luck.
