-   -   Plans for insulation/sheeting floor-What say ye (https://www.skoolie.net/forums/f13/plans-for-insulation-sheeting-floor-what-say-ye-4876.html)
paul iossi 01-26-2010 04:58 PM
Re: Plans for insulation/sheeting floor-What say ye
in my humble opinion, your plan to use the furring stips to backup the seams in the sheeting and also act as a spline is good, if you can get tongue and groove plywood and pull them together before fastening to the furring strips even better. just use a couple of rachet straps to pull the gaps up tight and then screw away.
Sojakai 01-27-2010 11:19 AM
If the furring strips are laid on top of the insulation, wont they compress into it over time?
Sojakai 01-27-2010 06:49 PM
Oh, your putting the strips between the sheets of insulation. I thought you were laying down the insulation as a big mat, then putting the strips on top.
