-   -   What can I substitute for a 9r22.5? (https://www.skoolie.net/forums/f27/what-can-i-substitute-for-a-9r22-5-a-4967.html)
Jarlaxle 02-15-2010 08:24 PM
Re: What can I substitute for a 9r22.5?
DO NOT REPLACE ONE DUALTIRE WITH ANYTHING OTHER THAN THE SAME SIZE TIRE! This is VERY dangerous! Replace it with another 9R22.5 or replace them both.
jkindt 02-15-2010 08:24 PM
You dont want to run different overall diameter tires on the same axle. You can change the tire size, as long as you change all of the tires on the axle. On the back this would mean 4 new tires. (Ouch! $$) Front tires are called steering tires and usually have a tread pattern and design specifically for steering. The rear tires, called drive tires, are designed for use on the rear, under power. In the end it is usually cheaper to replace the tire with the same size that the bus was designed to use, unless you find a really good deal on a set of 4 rear ones. You will also have to check with the tire shop to ensure you could fit wider tires on the back without rubbing each other as well, otherwise you would need to change rims as well. 8)
