-   -   "The Bondo Condo" - 15-passenger E350 Shorty (https://www.skoolie.net/forums/f27/the-bondo-condo-15-passenger-e350-shorty-5286.html)
Steve 04-29-2010 02:35 PM
Re: Took the leap!
Have you tried putting the bike in with the lift yet? I'd like to see some pictures of it being loaded.
sdwarf36 04-29-2010 10:09 PM
Re: Took the leap!
Nice shortie! Towing a boat will be no problem. I towed my race car + trailer (about 2k lbs combo) and never felt it back there. (That was with a diesel-but still..)
Jarlaxle 05-06-2010 05:40 PM
Re: My new 1996 E350 World Trans Shorty
You don't want to paint the bus black...it will be an oven in the summer even with the A/C!
Also, does that have 2 separate compressors on the engine?
dentedvw 05-06-2010 09:07 PM
I thought the paint looked pretty good from here as is. :D Is it rusty, bubbling, or what?
FWIW, I borrowed a sprayer, and it's hands down one hundred times better than rolling. I attempted the rolling method on one area as a trial a few weeks ago, and it was not so good. Then again, you have no huge ribbed areas on your bus.
You could rent a sprayer, or buy an inexpensive wagner type. Coverage, especially in the nooks and cracks and tight spaces is sooooo much better.
Cool bus. It's pretty clean, as far as I can tell. Good find.
jkindt 05-07-2010 08:59 PM
I think the brake rotor on your bike is bigger than the ones on your bus!!! Nice toys!!! 8)
Redbear 05-09-2010 12:39 PM
I think that batteries rated in Cold Cranking Amps are starting batteries, designed to give a quick high-current shot to get the alternator turning. More plates, but thinner plates, less acid.
I think that batteries designed for deep cycle use are rated in Ampere Hours, and have fewer, thicker plates with more acid.
Since you do not have a big battery bank, a couple of tips:
If you have not yet bought a microwave, look for a 'cheap' one with a rotating dial for the cook time. Ones with keypads and digital displays use a little current all the time to keep the computer actively looking for key presses. Alternately, unplug a keypad microwave when not in use, or put a switch on the outlet to kill the power when you are not cooking.
The same goes for a TV that you can 'turn on' with a remote control. If it can accept instructions from the remote, part of it is already 'on.'
sdwarf36 05-10-2010 07:12 PM
Re: Darren's 1996 E350 World Trans Shorty
My kinda guy! "where can I find something to make into something ? I need raw materials over here!"
I can't find the link right now-but found a place online that made doors for the body for just what your doing. Looked just like (and I'm sure are) whats used in motorhomes.
jkindt 05-10-2010 07:38 PM
If that is for your LPG tanks, don't forget to vent it properly. Propane is heavier than air and will settle in the bottom if there is a leak, even a slow one. Most sticks-n-staples units have expanded metal for the floor of the LPG tank storage bay. 8)
Jarlaxle 05-13-2010 05:30 PM
So, is the plan to carry that little car as a spare in case of breakdown? :p
sdwarf36 05-13-2010 10:29 PM
Man! How many hours in a day you got out there? I can't beieve how quick you're moving.
Heres a spare tire idea I had on my cube van. Works easy.
There is a fair amount of space from the between the fuel tank and the back bumper-just enuff for the tire. I bought a cheap crank winch-like on the front of a boat trailer. I welded the winch sideways to a frame piece near the back on the right side (would want to be lying out in traffic getting your spare out :shock: ) I cut the hook off the end of the cable-and fed it thru a couple of pulleys I mounted-one of them right over where I wanted the tire to end up. I made up an "H" out of 1" sq. tubing-large enuff to hold the rim up but sized so you can fit it thru the hole (10"X 4" from memory?) in the center of the rim and tied the cable off on the middle of the H. Slide the spare under the van-dish side up. Set the corner of the tire on a 2x4 or something so you can feed the "H" thru-and crank it up to the frame. I put a rachet strap on it hold it up-also a small safety chain. So the winch is more for lifting the tire rather than holding it up.(but it's still snugged up) 30k miles and it hasn't budged.
M1031 05-18-2010 07:08 AM
I'm saving pics and taking notes..........
crazycal 05-18-2010 07:34 PM
Originally Posted by Smitty
Looks great! Buy that dude in the pic a couple cheeseburgers :lol:
Smitty
.........and a tanning bed. :lol:
crazycal 05-19-2010 12:52 PM
Way to go, Mr. Wheeler Dealer. Nice seats.
putterspitt 05-19-2010 11:51 PM
what did the seats come out of? any idea?
roach711 05-20-2010 12:00 PM
I am also planning to convert a shuttle bus. I'd like a medium length skoolie better but I live in a "pinky's out" neighborhood and they'd have an absolute heart attack if I parked a big, yellow school bus in the driveway. LOL
Would you have interior measurements handy? I'd be interested in knowing:
1) floor length behind driver's seat
2) floor width
3) headroom
4) distance from floor to window bottoms
Any light you could shed would be greatly appreciated. :D
M1031 05-21-2010 04:13 AM
Originally Posted by DarrenDriven
The bike lift is complete! Head to the other topic to read the details and watch a video of the bike being loaded.
viewtopic.php?f=44&t=5934
https://www.skoolie.net/forum/download/file.php?id=2625
WOW!! Is that clean looking! Great job! :D
Stuff 05-24-2010 06:23 PM
great read! nice ideas on the bed and food station.
Jarlaxle 05-24-2010 07:04 PM
You're LIVING in the bus? Is this by choice...I hope?
M1031 06-01-2010 05:34 PM
Re: "The Gus" - Darren's 15-passenger E350 Shorty
One more thing, my bus has a name!
The Gus.
It's short for Humungus, who is Mad Max's nemesis in The Road Warrior. It also rhymes with bus, haha.
I just may have to modify Big Mac's name to BIG MAX!!!!! :lol: :lol: :lol:
Stuff 06-01-2010 08:07 PM
pulling a trailer could slip stream you a bit to. might not be too hard on fuel or even make it better. jeep guys do this all the time with the batam trailers behind them on the highway.
