-   -   power steering pump (https://www.skoolie.net/forums/f27/power-steering-pump-6540.html)
Atridox 04-18-2011 05:04 PM
power steering pump
My 1987 Chev C60 w/ Chevy 350 has a leaky power steering pump. Apparently, the power steering pump for this was a bit unique. Chev discontinued it and I have checked with numerous salvage yards and can not seem to find one. Is there somewhere I can send the pump to have it rebuilt (if that is even possible)?
dirtygoat 04-18-2011 08:35 PM
Re: power steering pump
Post up some pics of it and any numbers you can find on it...
Atridox 04-18-2011 10:33 PM
Here is a link to a pic of the ps pump
https://db.tt/kVbnLyv
otto802 04-18-2011 11:02 PM
Bummer, I think I have the same pump and it's leaking as well. My bus is also a 1987 C60.
baadpuppy 04-19-2011 08:17 AM
Have you tried removing it and taking it some place like NAPA? Often times there are equivalent parts that can be sourced and having the part in hand makes it easier to identify. Also, a parts place might be able to recommend a rebuild shop.
I think my '91 gasser has the same pump. I suspect a lot of the old farm trucks around here have one quite similar. Unfortunately, my '91 is spoken for after I'm done with it, so I can't offer parts.
Good luck,
jim
somewhereinusa 04-19-2011 06:23 PM
I think you'll find that the only thing unique about it is that extra reservoir on top. Chevy used that basic pump for many years on pretty much everything. I would think you would be able to find something with a similar bolt pattern. If I remember correctly some had a reservoir that was separate with hoses going to it. Where exactly is it leaking, the large "tin can" has an o-ring where it meets the main cast part right behind the pulley. I think everything is held together by the screw in fittings at the back, which also have o-rings. We used to fix them all the time.
The nice thing about "old things" is that they were made to take apart and be fixed.
dirtygoat 04-19-2011 08:28 PM
X2... Looks like a remote reservoir GM pump to me... Check out 1 ton Chevy's from the same era...
otto802 04-21-2011 12:18 PM
Maybe this seal kit will work? https://www.carpartsdiscount.com/auto...ml?3593=147173
