-   -   caulk removal (https://www.skoolie.net/forums/f13/caulk-removal-6660.html)
butcher_boy 05-31-2011 04:08 PM
caulk removal
what is the trick to getting off that pipe dope/caulk that resides on the floor and side walls all along the wall.
this stuff is very soft and gooey.
things I used to try and disolve it or remove it :
laquer thinner
goof off
caulk remover (from 3m and some other brand)
propane torch :D
the only thing that seems to work is a combo of nylon brush and thinner THEN pneumatic wire wheel.
so anybody else have a trick?
butcher_boy 05-31-2011 04:29 PM
Re: caulk removal
thanks for the reply. but it is way too soft to even pull it off.
GreyEagle 05-31-2011 06:05 PM
Re: caulk removal
In the Army........ If you can't move it.........Paint IT
lornaschinske 05-31-2011 09:33 PM
Re: caulk removal
I have been using a old set of my wood chisels (razor sharp ones). Had to be careful to not dig into the metal. First I used an appropriate width one to scrape the caulk off (I was also scraping silicone caulk off at the same time) then I used "Kleen Strip Deglosser" to wipe up (scrub off) the remainder and clean the chisels. Before I started using the wood chisel, I was using a straight razor and paint thinner. I got tired of wearing all those bandaids.
butcher_boy 06-05-2011 04:11 PM
Re: caulk removal
I am just going to paint over it. I tried removing most of it. but its like peanutbutter and cant get t all out of the floor welds etc.
thanks
b
00Arbor 06-21-2011 11:36 PM
Re: caulk removal
I just did this on mine. I got the bulk of it off with a flat bar and a hammer. Then I just went with a grinder with a 4 1/2" wire wheel to get the rest off. Worked well.
Arbor
whiterose764 04-09-2019 10:46 PM
Is it necessary to remove it? Did you re-seal with more silicone?
