-   Plumbing, Water and Waste (https://www.skoolie.net/forums/f50/)
-   -   Toilet installation (https://www.skoolie.net/forums/f50/toilet-installation-911.html)
captainkf 11-17-2005 04:19 PM
Toilet installation
What is the longest run that is still functional for rv toilets? Due to some new tanks I am concerned about the distance the line will have to be from the toilet to black tanks. Would 6' with three 45 degree bends be too much?
-Richard
Roasting8 11-18-2005 02:02 AM
Hi Richard,
Your runs should be as short as possible. Normally, the black water tank is positioned right below the toilet. The reason for this is that unlike home toilets, RV toilets don't use as much water to flush the fecal matter to the tank. Thus, with a long run (like the one you mentioned), the crap will not get to the tank with the one flush.
Also, don't forget to vent the tank.
Ryan Grimm 11-22-2005 11:32 AM
The more bends you use, the more clogs you'll get, depend on it. And every second bend or so should be a cleanout to deal with those clogs. Do you LIKE working with old poop? :-)
RV black tanks are directly below the RV toilets so they drop stuff right in. They do NOT use bends.
Domestic toilets are right by the main drains, and use all of that water to flush stuff down the pipes. Unless you plan on HUGE fresh and black tanks, don't use a domestic toilet.
Besides, RV toilets start at $90 or so for portable units, similar price for fixed units. Go with an RV toilet, and keep the thing right over the tank.
captainkf 11-22-2005 04:10 PM
Re: Toilet install
Thanks for the info. I figured that over the tank would be optimal, however I wanted to confirm. I now have a 60 gallon black tank and thetford rv toilet to install. Now I have to wait for the spring to get on with it. :(
I wish I could just find a warehouse or garage that is waiting to do be leased or somthing so I would have somewhere dry and secure to work on it over winter that doesn't cost a fortune. I guess I'll have to wait.
This just gives me more time to source things for cheap or free.
-Richard
JoeA 12-09-2005 08:44 AM
How do you actually install the RV toilet??
I have an Aquastar V.
it has the regular Flare around the Hole with a gasket that fits on it and two bolts that according to the drawing go in from the bottom up to tighten the thing to the floor, but ??? how do I get that hole to my Holding tank which is directly below it. I'm sure I'll figure it out but ? Do I put some kind of fitting in the hole through the floor before I fasten the toilet to the floor?
fankhaj1 12-11-2005 07:54 PM
I have a question here? Our family has a boating legacy and I am wondering can you install a black tank at a distance and use a macerator like pump? The design I am working on would require the bathroom to be 18" higher than the main floor to allow for a tank under the bathroom. I don't want that! I remember in boats that holding tanks are a long distance from the head and all of them require a pumpout. Couldn't a person install the tank a long ways away if they just pumped the ?oo to the tank and possibly from the tank?
Has anyone tried that?
Thanks
wtd 12-11-2005 11:20 PM
I believe that you'd have to use an a macerator toilet, as used on boats, rather than a 'normal' RV toilet and separate macerator pump, but I don't see why it wouldn't work.
Tom
busone 12-12-2005 01:30 AM
You could put a small tank under the head. Then put the macerator in the small tank to pump the crud to the main black tank. I personally have not experience with macerator pumps but I have been told of many bad experiences with the RV models. Most people reccomend to use marine versions.
vonslatt 12-21-2005 09:06 PM
Just like this:
https://www.vonslatt.com/images/bus/t10toi.jpg
More pictures here:
https://www.vonslatt.com/bus-plumb.shtml
