⚠️ Death from RV Tapwater, CDC Warning⚠️
DeMac
🚍Bus Lunatic🤪
Oct 12, 2020
1,888
Central FL
CDC ⚠️ Warning RV Tap Water and Associated Death
"The Centers for Disease Control recently reported that a 71-year-old woman died in Texas in 2024 from a rare brain infection caused by tap water in her RV. She used that water to wash out her nose." Dr. John Flores of Little Elm said
The Hill- Woman dies from brain-eating amoeba after using tap water to clear sinuses: CDC
A Texas woman has died after contracting a rare infection from a brain-eating amoeba while using tap water to clear out her sinuses at an RV campground, according to a recent report.
The Centers for Disease Control and Prevention published the death investigation in its Morbidity and Mortality Weekly Report last Thursday, stating that the patient was an otherwise healthy 71-year-old.
According to the report, she started experiencing serious symptoms like a fever, headache, and “altered mental status” within four days of using a nasal irrigation device filled with tap water.
The woman received medical treatment for the suspected Primary Amebic Meningoencephalitis (PAM) infection, but according to the report, she started having seizures and died eight days after the symptoms started.
Through an investigation, the CDC confirmed that Naegleria fowleri was found in the woman’s cerebrospinal fluid.
“If water containing the ameba goes up the nose and to the brain, it can cause an infection called primary amebic meningoencephalitis (PAM),” the CDC said. “Typically, fewer than 10 people a year in the United States get PAM. Nearly everyone who gets PAM dies from it.”
According to medical records, between 1962 and 2023, the United States reported 164 cases of PAM. Of those cases, only four patients survived.
Very rare occurrences. I've been hearing a lot in the news lately about brain eating amoeba's. Wonder why the CDC's pushing such propaganda now? Attempting to scare people from living in RV's?
Nothings changed in the water. There's not an increase in deaths from such a thing, only a flare up of the propaganda. Reminds me of the time the World health organization said bacon causes cancer to keep people from eating red meat.
# Sanitize your fresh water tank at the start of the season and drain it if it will be unused for more than 2 weeks (you should also do this is you ever get bad water in your holding tanks). To sanitize the tank and the fresh water system, do the following:
1. Prepare a chlorine solution using one gallon of water and 1/4 cup of Clorox or Purex household bleach (5% sodium hypochlorite solution, NOT THE SCENTED STUFF). Pour one gallon of solution into tank for 15 gallons of tank capacity.
2. Complete filling of tank with fresh water. Turn on the pump. Open each faucet and let it run until all air has been released from the pipes and entire fresh water system is filled. You should be able to smell chlorine strongly at each faucet.
3. Allow to stand for three hours.
4. Drain and flush the tank and system with potable fresh water.
5. To remove any excessive chlorine taste or odor which might remain, prepare a solution of one quart vinegar to five gallons water and allow this solution to remain in tank overnight or longer.
6. Drain tank and again flush with potable water.
# If in doubt about the quality of the water going into your fresh water tank, add a small amount of common household bleach to the water in the tank. A teaspoonful of bleach per 20 gallons of water is plenty!
We use filters ( a sediment filter and a whole house 0.5 micron) not bleach. We did end up in a campground once that had bad water. We just didn't realize how bad. We didn't drink it but the dog and cat did. The dog was young and healthy. she recovered. The cat was healthy but very old and "fragile" is the best way to describe her. She picked up something that messed with her urinary tract (she cried when she would pee and she seemed dehydrated). Vet could do nothing. Suggested putting her down rather than the very, very expensive operation that she probably wouldn't survive due to age. We did get her better but it took about a year to do it. She lived for about 3 years after that. She never did completely recover. She always got a cold before anyone else did (something she rare did before). She was listless all the time. the cat was between 20 & 25 yo when she died. Lesson learned... we all (pets included) drank bottled water or water from home when camping. With the RV, I put together a filter setup together because we were staying long term, in an area with a lot of agriculture, high fertilizer use, and very sandy soil. My filters filter out just about everything without hitting the Reverse Osmosis (RO) level of filtration. I put the filter system inline when filling the water tank while traveling. We would never know we had taken on bad water until it was too late and possibly several states away. Keep a bottle of sanitizing solution to spray down the water pipe spigot. ALWAYS use your own hose to fill your tank with... you know where it has been. I have heard and personally seen horrible, nasty things done with dump station potable water hoses. Trust me on this one... sanitize the spigot with a trigger sprayer (even up inside the spigot) until it is dripping and ALWAYS, ALWAYS use your own water hose to fill your tanks with. If all you have are long hoses, then pick up a 6 to 8 ft shorty (or cut one down) just to travel with for filling the tank.
Lorna's Original Post
Animals & children rely on our efforts to ensure their world is safe.
Yes absolutely clean your tanks often. I'd likely do it before each use as I wouldn't be using it daily, and it would have time to "grow" things in the tank.
Iodine tablet is a good thing to throw in there once in awhile as well.
@DeMac did you get more animals?
Scary stuff makes the headlines, pure and simple. The CDC puts out a morbidity report every week on some topic. The focus of this one was more about nasal irrigation risks. Texas wants to promote RV safety for tourist dollars. Processed meats do, in fact, increase the risk of bowel cancer, especially when cooked at high heat (bacon).
I don't buy it. Bowel cancer is also rare. The whole overcooking food thing is also a recent thing they've been spitting out too in the narrative. "Don't overcook your food, the ash is bad for you!!"
Yet several generations of my family and others all eat overcook bacon daily their whole lives and not a single one got bowel cancer. There are definitely things that cause cancer, but bacon is not one of them. Not in any kind of excess anyway. When I'm 80 years old and still eating crispy bacon, I'll be sitting there laughing at people who deprived themselves their whole lives of good breakfasts.
The three most common types of cancers are breast, lung, and colorectal. It's not the ash, but the chemical changes to the preservatives in processed meat, mostly nitrates. Facts are stubborn things. Eat scrapple - it's grey, no nitrates!
Nikitis, facts are more stubborn than you are. What you are calling rare is in the top three for being a cancer that kills people. It is a fact that the nitrosoamines formed when cooked nitrite/nitrate preserved meats to the point of browning are carcinogens -- yes, it's worse the darker you brown it. That is something that category of chemicals does. Maybe by being otherwise healthy, having good Vit D levels, etc., that increased risk can be completely offset -- it's still always only a crapshoot.
Pretending you're not in the craps game because you think someone wants to rig some other game, is just being a Flat Earther.
CDC ⚠️ Warning RV Tap Water and Associated Death......
I appreciate the post and don't believe this is a conspiracy from a government agency to promote fear of RV's. Every year one can read a story about this disease caused by warm water from different sources. The most important fact is that if you get it, you probably will die. :(
HRM I wasn't aware Collin cancer was so high. I've only ever known one guy in my life who had it. I've seen far more testicular cancer and pancreatic cancer in my circles. I've probably known more people with brain cancer than Colon.
Yep … colon cancer is one of the most common ones… my dad passed away from it and my father in law had it…
A couple of other tidbits for you: it’s one of the most treatable if caught early, and the incidence is on the rise in younger adults - like as early as in their 30’s and 40’s …
Used to be was the guideline get screened starting at 50; believe that is now 45, and if you have polyps, recheck every 3-5 years…
This same thing happens from swimming in fresh water lakes, and can happen with tap water from home. Water going into your nasal cavities should always be boiled first, or better yet, use distilled water for this purpose. The RV didn't have anything to do with it.
Here is some food for thought. One of the byproducts of treating water with any organic mater in it is the formation of haloacetic acids. Any type of halogen, chlorine, bromine, iodine and others, including ozone will cause the formation of HAA’s. It is an EPA regulated contaminate linked to bladder cancer in drinking water that has been treated. So if you have used chlorine in the tanks they need to be flushed very very well before refilling. The water you fill it with has more than likely been chlorinated too. It can also be absorbed through the skin although not the same danger as drinking it. Charcoal filters are good at removing it but must be changed regularly or they can become a source for bacterial growth.
How to Safely Rinse Sinuses​
  • When rinsing your sinuses or nasal passages, use store-bought distilled or sterilized water, or tap or faucet water that's been boiled and cooled.
I'm gong to say something that is probably going to get some here riled up, but personally all of this is the same kind of fear mongering that was used during covid. The likelyhood of getting any kind of brain eating amoebas from your potable tap water is zero. They use so much chlorine in the city water it's very unlikely to happen unless the city allows so much water through without it being chlorinated in which case the city is required to warn people to not drink their water for a day or two. Boiling is not required. We used tap water all the time to clear our kids sinus's and nothing ever happened.
People have swam in fresh water lakes since forever and people rarely if ever die from the causes listed here.
Indoor pools that do not see the sun ever can be an issue if not heavily chlorinated. Sun = UV Light which kills such things near instantly. UV kills so instantly in fact UV devices put In-line on water lines makes it safe to drink just passing through it fast in a pipe and have made water that people even in Central Africa drink safely on the daily since they discovered UV light devices. Fresh water lakes are exposed to the suns UV. God thought of this so we can swim in them without fear. Don't let people scare you into not being able to swim and enjoy his creations.
Lakes that have corporations along them may not be safe due to dumping chemicals into them so you do need to check to see if any body of water you swim in is connected to such a thing up stream. This is a big issue in West Virginia. They have some of the cleanest drinking water naturally but has all bee polluted due to corporate dumping into their rivers.
After covid, I can't idly sit back any longer and let people read some of this stuff as it instills fear and I have to personally deal with those people down the road when I want to do things like swim freely in a lake so I have to do my part and comment. If you disagree that's fine, but I don't want anyone giving me crap down the road when I want to exercise my freedoms and get interrupted because of your fears. After covid, I'm frankly done with dealing with these mentally ill type of people in person and I'm not alone. We no longer live in a world where people are going to tolerate this kind of crap any longer.
