SurfingDog-SKO
- Joined
- Jan 10, 2025
- Posts
- 12
I am going to preface this by saying: I have heard it a hundred times that Maxxforce is junk. I get it. EGR bad. DFP bad. I agree! No DEF on this rig.
Anyways; my bus has 85k miles, 3300 hours, and I have ZERO maintenance records on this beast. I have zero knowledge on diesels or rigs of this size but I am very motivated and interested in learning. I DIY'd my way to engine swapping, supercharging, self tuning my 90's Mustang, and I came directly from playing World of Warcraft daily for years with zero car knowledge 6 years ago. Now this is my next project to learn!
At purchase a month or so ago it did great on a 2 1/2 hour drive back home. It sat for roughly a month until driving it to get it plated, registered etc yesterday. It was an hour drive away from home. Checked over everything well before leaving and everything looked great except the batteries were completely dead for who knows how long. I charged the batteries and got her fired up. I went down the road, made a stop, and after I left from that stop it had a loss of power. No lights, no icons, no sounds. It would struggle going up hills and I thought initially it was a transmission issue but I learned it was definitely power loss related. Up hills I'd go from 55 to 40mph even with the pedal to the floor.
After I made it to my destination I parked for roughly 15 minutes and fired her back up. Noticed the hot exhaust temp lamp on that's to the direct right of the LCD panel. Fired it up 30 minutes later and no more exhaust lamp. I drove across the lot and noticed it was struggling at low speeds / pedal. Cutting in and out and struggling to gain power. Did not seem like an ECU limit by any means because once I pressed the pedal down further it'd "kick in" and take off. I don't remember when but an exhaust cloud with an exclamation mark lamp turned on which lead me to find it was emissions related. Had to get it to op temp to do a parked regen (thus learned what parked regen was lol) so I went down the road to get it warmed up quicker since idle wasn't getting it much past 150F and the parked regen button would flash when pressed OR held for 3-5 seconds.
As I took off up the road it had the "stage 3" lamps light up with an audible alarm going off while I came to a stop at a red light. I tried to get over to see if it'd regen and to get out of the road but it went away after about 5 seconds. Continued driving around on back empty roads to get the temps up and it never would regen nor did the issues clear up. I decided to take off back home an hour drive back home from many recommendations to keep it higher RPM that it'd maybe clear up since regen lasts 20-30 minutes at 1500-ish or so RPM but I believe regen will specifically dump more fuel in for hotter EGR's correct?
Once I made it back home it seemed almost to clear up from low load / accelerations but top end power is still down. I made it back home just fine and noticed the "stage 1" emissions lamp was gone. Decided to climb underneath to visually check everything out around the DPF and everything looks clean, plugged in, etc. Pulled codes and have one active one which I am unsure how to look up: SA 33 SPN 520916 FMI 13. If I am right it's something EGR valve related? Any help will be greatly appreciated. I had a fuel filter replacement needed pop up on the LCD panel last time I drove a month ago but it's not reappeared. Going to replace it and look over everything on the engine top to bottom. Going to assume about everything needs to be serviced so I can become familiar and both record it.
