jcalvinmarks
- Joined
- Jun 4, 2021
- Posts
- 2
We've had a bad week with our bus (1987 Thomas Chartour). After our last short trip, I discovered that some coolant had been pushed out through the overflow, and then discovered coolant contamination in the oil, after which point I drained about a gallon of coolant out of the oil pan. Long story short, I'm pretty confident we have a crack in the block, so this bus is going to need a new engine.
So the question is, what are we going to do about it? I figure we have three basic options:
- Swap another Cat 3208 from a Thomas bus. I would assume this will require the least amount of fiddling since the engine will already be configured for rear-engine application in a bus from the same manufacturer. But the very newest buses with a 3208 are no less than 20 years old now, and are likely to be several years out of fleet/revenue service. So mileage and condition are going to be a big question mark.
-Swap another Cat 3208 from a fire truck, probably a Ford C8000 or similar. Fire truck engines are likely to have very low miles and are generally like to be well-maintained. But I have to imagine that it's going to require a little bit of engineering to convert from a cab-over truck to a rear-engine bus.
-Swap for something else entirely. I had a mechanic recommend a Cummins 4BT, but going from a 235hp 10.4L V8 (which even at that feels under-powered at times) to a 4-cylinder 3.9L that makes only just 100 hp doesn't seem like a good fit. What other engines should I be considering. It would need to be all-mechanical, since there's no wiring harness for anything with an ECM, and mate up to an Allison MT643 transmission.
