Make Offer (Cash or?) $5900 OBO. Has original 69,567.1 miles. Very good 7.3 diesel engine and solid bus that is ready for conversion. Seats removed. Has new batteries. Starts, shifts, and runs solid. Does need a good clean is due for an oil change. The tires will eventually need replaced. I believe the rear passenger break is sticking, so breaks may be needed soon. The AC belt broke, but compressor is good and still as refrigerant. It does have air lift with good compressor, but I believe there is leak somewhere. Clear Title and ready to be notarized for new owner. Located in Yukon, OK 73099.
1. Date of MFR: 09/92
2. MFR by: Ford
3. GVWR: 16,500
4. GAWR Front: 4,200
5. GAWR: Rear Duals: 7,800
6. Tires/rims front: LT225 75R /16x6k (65psi cold) X2
7. Tires/rims rear: LT225 75R /16x6k (55psi cold) x8
8. VIN: 1FDKE30M1NHB47902
a. 1FD = Ford Motor Company Incomplete Vehicle
b. K = GVWR 10,001 – 14,000 Hydraulic Brake System
c. E30 = Ford Econoline, E-350 RV stripped chassis ('85-'91)
d. M = IDI 7.3L Indirect Injection Diesel Ford E Series
e. 1 = 0 GOOD
f. N = 1992
g. H = Lorain Assembly (Lorain, Ohio)
h. B47902 = Sequential Number
9. Body Type: MY
10. Model: 35C
2. MFR by: Ford
3. GVWR: 16,500
e. 1 = 0 GOOD
f. N = 1992
9. Body Type: MY
10. Model: 35C
