Hello,
Needing some help diagnosing an issue.
1993 gmc blue bird, 366 tonawanda gasoline carburetor engine.
Was running fine two weeks ago and won't catch now. Opened carb and there is no fuel coming out of injectors, not a single drop. Changed MAP sensor, no luck. Pulled a spark plug and noticed it wasn't sparking. Opened distributor and cleaned very minimal decay off connections, no change. All fuses are validated. Emergency doors are closed/unlocked. Dont believe it is ECM because all other electrical systems work fine, i can hear the fuel pump kick in with the key turning. I'm thinking of buying a new distributor, but want some help diagnosing. Has anyone ever had this type of issue?
