davisdesigns
- Joined
- Sep 7, 2015
- Posts
- 65
about 80-85% finished. located at 95928 Asking $30k for all, tools supplies etc.
Need to sell ASAP, or find a place to store and work on it. Lost the place to store it and my job of over 10 years also looking for work 3D design, metal fab, electrical pretty much anything mechanical/ electrical I can make or repair. Have "chronic Lyme disease" for about 12 years now but recovering slowly w/ new treatment and natural analgesics. This has put an immense amount of unnecessary stress on me. I have put every bit of savings I had into this and medical and worked every weekend and many weekdays for the last 3-4 years. I’m a month away from being homeless which is pretty much a long painful death sentence having chronic illness.
State medical assistance doesn’t cover anything unless one has positive Lyme markers for their 30% accurate test here on the west coast.
I built everything from scratch including many tools to make things for the bus, die’s, bead rollers etc.
I have pretty much everything needed to finish including the kitchen sink, minus some sheet metal and plywood hardware. All in the photos is included, all the solid bamboo flooring of two types, western red cedar for the closet, bathroom, Diesel generator w/2 hours on it, 23 solar panels and aluminum for the frames to go up top, all the tools needed saws, TIG and MIG welders etc.
It has 2 custom stainless steel freshwater tanks 100 gal each, a 200? Gal graywater tank. I have a 3D CAD model and terabytes of video and pictures of how everything was built for reference I don’t have the internet data to send you or upload video so don’t ask also don’t ask if you have no interest in buying it, I don’t have the time or energy to help you now, but that was my intent upon finishing it to help others that lack the skills or tools.
Just too much to list so ask specific questions.
Some things in the photos are temporary like steps and shelving in the “bathroom” area so ignore the craftsmanship on things like that it was just thrown together.
More images linked here, https://drive.google.com/drive/folders/1s95y0iJ-MwYUtN3zXChKM-YJZrelWUIM?usp=sharing
1998 BLUE BIRD 38' 8.3L Cummins Allison B300r transmission
*GVWR is 36000 current weight is 19400 that leaves a lot additional
weight you can put on
*Currently registered and non-op'ed
*Partially converted to motorcoach, most of the difficult tasks..
*Roof raised 16 in. the goal was to stay under 12 feet with a roof deck.
Roof deck mounts securely installed and sealed to the Hat Channel "ribs"
This is not a school bus so the arch on the ceiling is much flattered so you have more Headroom towards the sides of the bus. The 16in roof raise has head clearance for me to stand up straight with my arm and finger fully extended and just barely touch the roof, I'm 5'-10".
Also the roof was raised done at the floor so the windows aren't at crotch height when standing, Which is what happens when most people do a roof raise they cut at the windows and lift the roof. You're able to see out of the window sitting or standing. I also cut off the front cap and windshield and raise that up I believe 12 in this increases privacy, head clearance any better View.
One very unique thing you will never find on a rear Diesel Pusher is a back door. A custom-built a raised, insulated rear deck over the motor that that has hatches to access the top of 8.3L. I can stand up straight with a few inches of head clearance directly above the motor. This was built for a garage area but would probably be better utilized for someone else as a bedroom.
Floating insulated subfloor, by floating I mean that no wood is actually contact the sheet metal there is an approximate quarter inch air gap between the subfloor and the OEM sheet metal floor. Insulated with 2 in. ISO foam board foil backed both sides all glued screwed and tattooed.. This dose several things 1. adds R value 2. if any moisture where to get between the subfloor and sheet metal it will evaporate and not rot the metal and wood. The underside of the sub floor was painted as well, no mold or rot.. Not a half-ass build.
Floating insulated ceiling buy floating I mean it is only connected at the Hat Channel "ribs" insulated with 2 in. ISO foam board foil backed both sides with an approximate half inch Gap between the tongue and groove 'solid' 5/8 bamboo vertical grain. none of that cheap composite with 1/8 in laminate garbage, all solid. Glued and finish nailed 16ga.
Walls have been completely gutted as well as the ceiling all nasty old insulation torn out and replaced with 2 in.ISO foam board foil backed.
The walls have been fully framed out with welded steel hangers for the two by four studs they are in set to increase interior size. Currently partially covered with tongue and groove solid bamboo horizontal grain.
All new 18ga. sheet metal on the sides, sealed with butyl rubber and riveted every 3-1/2 in. with steel 3/16" Q-rivets 100% mandrel retention i.e. no leaky hole. 'quality rivets made in the US' All rivets were dipped in butyl rubber prior to installation for additional sealant.
Paint/ primer first primer 2 coats epoxy based with a seal primer of Rust-Oleum professional iron oxide and painted with Rust-Oleum professional oil based paint that I custom mixed. I have the ratio and colors used and about a gallon of leftover. The paint job isn't the best by far, unfortunately I had no choice but to paint it at night time with very poor lighting so every backstroke has orange peel it has two coats of paint so if you wanted to wet sand orange peel out you could.
The bus comes with a diesel generator that has 2 hours on it (HDI700BD Electronically controlled direct injection diesel generator, 10HP w/auto idle control, AVR, Auto Start, and low oil shutdown. 120/240v 30/40 AMP $6,960.00 Retail) More than enough bamboo flooring both vertical and horizontal grain to finish everything, floor cabinets etc. (3) or (4) rolls of bamboo matting for cabinets doors or cabinets its carburized (dark) about (24) packets of Aromatic western red cedar tongue and groove $26 per box, I was planning on using for the bathroom area and walk-in closet. A diesel fired water heater OEM. (23) 130 Watt solar panels used but tested that we're going to be mounted above the roof deck to tilt out. (22) will fit on the roof, A brand new solar charge controller Morningstar TriStar 60 Amp MPPT and remote $700, connectors etc. Hardware, adhesive, sealants pneumatic tools, table saw, miter saw, bandsaw, radial arm saw, another table saw, a humongous stainless steel sink brand new about $300. Metal tubing, sheet metal pieces, etc. Some power tools, sheet metal tools.. Pretty much everything you'll need to finish it minus a MIG welder if you chose to finish it by welding the lower cargo together as well as bumpers etc.
Stuff that needs to be finished;
*Interior minus roof subfloor
*Front and back bumpers or use the original ones.
*5 lower cargo Bays
*Plumbing
*Electrical
*Hinges for back door and furnace door
*Roof deck access
*Roof deck
*Solar panel brackets
*Batteries and tray, I was going to run a 48 volt system..
*Composting system or Blackwater if you want to go that route.
There is a 200? gallon grey water tank installed.
*5 lower cargo Bays
*Plumbing
*Electrical
*Roof deck access
*Roof deck
