Done.
Hiya.
So it turns out that updating Skoolie.net is not one of my strong points. My last post was in mid 2018. It's been a busy year, we've had a baby boy to bring us up to a family of 5 (the other two just turned 4 & 2). My visa situation meant that we had to leave Canada for a while, lots of stress.
In terms of the bus, we've pretty much finished. It seems weird to look at the photos from last year now, with hundreds of hours of work between then and now. I wanted to follow up because I know plenty of projects get started and never finished. It's taken a lot out of us, but we're there... Kind of.
We have been living in the bus full time for over a month now. We're living in an old forestry fire base, which is pretty cool. I've learnt a bunch, come close to tears and probably knocked a few years off my life from anxiety. I've shot a brad nail through my finger, worked through -25 celsius, pulled a fair few 16hr days, all whilst never really having a clue what I was doing.
So, last time I posted we had just about framed and insulated. It was basically a blank slate at that point. since then -
Flooring - Douglas fir T&G, super satisfying to put down
Plumbing - Installed the full plumbing system, including two 50 gal fresh tanks and a 44 gal grey tank under the bus. City water, tank monitors, etc. I got totally lost with connecting up the appliances and as we were running short on time, I brought in a plumber to connect everything up. Sink could drain a bit better but otherwise pretty happy with it all. Bathtub is a galvanised animal feed trough which we painted with enamel. We also have an external shower near the front door.
Kitchen - Installed some Ikea cabinets in a galley style and made a custom Douglas Fir wrap around countertop, which was an awesome project. We have a sink, fridge (120v), water heater (propane, battery ignitor so not connected to the 12v)
Propane - Installed the propane storage in the 'basement', tried to run the lines and struggled so went the same way as the plumbing - got a guy in to connect up the appliances - water heater, propane stove and a 4-burner cook top as well as a BBQ quick connect on the outside.
Climate control - We have a Dickenson P12000 stove, it's getting cold in the Canadian rockies now - just about hitting freezing at night. Our stove JUST about keeps us warm, it generally keeps the living area 10-15 degrees above external temperature at night. We never designed this thing for winter living - we purposely left 13/14 of the single glazed windows on each side of the bus to maintain the bus feel and to give us loads of light. However, I did put in a decent amount of insulation so that counteracts it. A little. We put in two fantastic Fans in the roof, which were great when it was still hot.
Bus 12v - I ripped out the redundant wiring, which is a great way to get to grips and gain confidence with 12v. Plus an awesome source of wire for the rest of the project. Wired in the old school bus lights with the signals/brakes at the back and signals/switched flood lights at the front. Had a problem with a short in the signals somewhere, we had to get a mechanic to sort that out and he sorted it by replacing a couple of bulbs and grinding down some badly corroded ground connections.
House 12v/120v - I absolutely loved this bit of the build. I've got four 6v batteries in a vented box in the basement which puts me at 420ah, as well as a Go Power 2000w inverter, 400w of Renogy solar on the roof with a 30a MPPT charge controller. We have usb points and 120v outlets spread all around the bus. Also have the stove, roof vent fans, lights etc. 30a shore power, AC panel with plenty of outlets, wiring for a potential Air Con unit in the future and a 120v fridge.
Toilet - Installed a composting toilet, works a treat. Accumulated urine smells weird.
Paint - My partner nailed this one, it took her probably 1.5 days prep in taping up etc. and then another day to paint. We'd already done some prep as we went (removing stickers etc). and had done the roof in RV roof paint. I personally think it looks a bit like a cheap cocktail that you'd get on a beach.
Mechanical - The compressor kicked the bucket so we had to get that replaced - $1500.
Bus upgrades - We took out all the seats in the beginning and would have loved to have installed some nice swivel chairs for the 4 passengers. Space didn't allow so we ended up re-painting and re-covering two of the old seats before re-fitting them. Bus chiq? Combined the doors into a single door with a deadbolt and a latch. Also upgraded the entrance way after I slipped down it and nearly broke my arm - rubber matting, auto carpet, trim etc. Built a couple of passenger walls to make the journeys more enjoyable for the kids and added in a few 12v outlets. Added a back up camera and I still have a dash cam to install.
Finishing - We stuck with the Douglas Fir theme, I would have loved to have gone with Cedar but the cost would have been double. We finished up the walls and ceiling with more, thinner, T&G. Built a sofa/storage unit, pop up table. Our idea was that we wanted to have the 'living area' as open as possible so that on rainy days the kids could have some space to play indoors. It works really well, doesn't feel cramped at all. We also left the two bottom bunks as an open space and we're currently using it as another play area. If we still own this thing when the kids are older then we'll be turning this into one/two more beds. We have a huge double bed in the back and the views out of all the windows and the emergency exit are amazing. We renovated and installed some luggage racks from an old bluebird so we have absolutely loads of storage, though it does look a bit cluttered - living with 3 kids under 4 in a bus means you have to accept a certain degree of mess.
Converting the title - Changed from a commercial vehicle to a motorhome. This felt like a massive step and I wish we'd done it earlier - we hit a problem in that getting the vehicle signed off proved a very tricky process. We had to wait until after the roof raise so the inspector could see that was done properly, then he basically inspected it as a bus when it was already a motorhome. Complicated and frustrating.
After my visa situation changed, we had a long think about what we were doing and decided that we wanted to hit the road full time and head as far south as we could get in this thing. However, we hit an unexpected problem. Without going too deep into it, we worked out that we currently don't have the correct licences to drive the bus. Our BC licences would have covered us but they expired at the end of my visa last year. We're about to head back to the UK to upgrade licences (Cat C ('HGV') for anyone familiar) which should leave us good to head out in spring, when the campsites have all re-opened. We're currently winterising and storing the thing (hard work here in the middle of nowhere!).
Wow, that's a long post. Hopefully I've covered a lot of the stuff that people might be interested in, feel free to ask if you want to know anything specific. Obviously we still have loads of stuff that we'd like to do but we are fairly over it at this point, I think a little time away from the bus and spent with family will do us good. Very nervous about leaving our rig here and hoping for a mild and uneventful winter for it.
Thanks to everyone on Skoolie for their help. I haven't engaged with the community as much as I had originally intended but I have totally stalked most of you and your builds. Our bus, like many I suspect, is more of a mash up of other people's ideas with a little of our own style thrown in. There's no way i would have been able to get to grips with all of the utilities without this website so I appreciate it.
Sorry for the poor photos, I've taken hundreds but haven't had the chance to go through and pick out the best. There's so much to show that our tiny little cellular router would explode if I covered everything. Also, loads of our pictures have us/the kids in them and I'm not to keen to post them on the web! Again, any questions then ask.
