Moto955
I have a 1999 Thomas Freightliner FS65 Cat3126B with No crank No start that is random it started 3 years ago but was short lived and I would tamper with the relays behind the glove box and it would work. so I thought is wat just a bad connection. Now that does not work. with the extreme cold it has made it hard to get out and check things so with all the home i have done I have a few questions.
I do NOT have an exact wiring diagram for my model so if someone does that would be great if you would share it. Every one I have found is for later models with the exterior side panel electrical vs the one inside.
all the dash warning light work as normal but Where is the inline fuse for the ECM?
The solenoid for the induction heater was bad and put a new OEM one in but it still doesn't work so I need to check for Resistance on the element. was wondering if that had a temp sensor that might not let it start?
I'm hoping to get out in the cold to do some checking and will report back.
I do know that it does not have anything to do with the Vander lock system. Any ideas would be appreciated
