2 Kool 4 Skool build
Hi Don/Mary, quick question on the seat rails, why did you choose to leave them together with rubber/plywood subfloor?
We bought the exact same bus from a place in Glendale AZ and I feel the rails are a part of the chassis to frame connection. Also, except for a few tiny cracks in the rubber surface the plywood is not deteriorated at all with metal subframe lacking any rust or damage of any sort. I'm thinking a layer of insulation with bamboo flooring on top should suffice.
I just need to hear your reasoning for moral support..! ;-)
I got my bus from Mesa AZ. and it has the aluminum seat rails, 1in.plywood and rubber flooring . I checked for rust but couldn't find ANY. So I just put it all back together minus a lot of unnecessary bolts and covered it all with 1/2 in plywood. My experience is flooring insulation really doesn't help, that much. I'm still in the conversion stage but we've used it a number of times and it has worked well that way. This is just my actual experience.
It will run everything on smart throttle but the water heater, the space heater and the toaster oven, those need full throttle.
What are you running for a water heater? I couldn't find reference to it in all these posts. I'm assuming it's a 120V? I'm trying real hard to avoid having to plumb propane into my bus.
Update on ballast weight removal?
Hi Don - I know this post is from five years ago, but I wonder how things worked out for you after removing your ballast weights? We have a 2000 Blue Bird TC 1000 with similar weights, and are considering removing them. We don't plan on doing a whole lot of winter driving, but can't rule it out on our way to the SW in January from Washington State. I don't have a current weight on my bus, but do plan on getting front/rear axle weights soon.
Others have told me they had to remove/reattach exhaust to get some of the plates out. How was your experience? Were you able to get $$ for the scrap?
Thanks, Tom
Our BB has 4 ballast weights, all 4 are behind the rear axle. I removed 3 of them.
They measure 6in. thick, 8in wide and 28in long. That makes a combined girth of 34in x 28in x 6in. They are steel plates welded together and have a 1/4in thick support frame.
I am able to lift only one end of these and I'd say 300 lbs each. What's your estimate?
I will be scrapping these so I can find out what they weigh.
Got the 2 15a circuits started. The load center's in the pic. (20a breakers, all I have right now...15s later.)
C1 will serve the water heater (switched) and 2-3 other outlets.
C2 will serve the window AC and 2 others.
Gen power is the 30a receptacle.
Never mind, I didn't see the date
