From EGES-175-1
Diagnostic Trouble Code 143
ATA Code SID 21 FMI 2
Incorrect Number of CMP Signal Transitions per
Cam Revolution
Diagnostic Trouble Code 143 indicates the ECM
has received CMP signals with the wrong number of
transitions. This indicates that the ECM has counted
the voltage transitions and found less than the
specified number of pulses fromthe sensor. When this
problem is continuous, the engine will stop running
and the ECM will log an active Diagnostic Trouble
Code. If the ignition is shut off, the active Diagnostic
Trouble Code becomes an inactive Diagnostic Trouble
Code.
Diagnostic Trouble Code 143 will not turn the warning
light on.
Possible causes for Diagnostic Trouble Code 143:
Intermittent CMP signal caused by a intermittent
circuit, defective Camshaft Position Sensor, or
incorrect CMP sensor to timing disk clearance.
Diagnostic Trouble Code 144
CMP Signal Noise Detected
Diagnostic Trouble Code 144 indicates that the ECM
has detected voltage spikes or transitions other than
the CMP signal. If this problem is continuous, the
engine could stop running and the ECM will log an
active Diagnostic Trouble Code. If the key is shut off,
the active Diagnostic Trouble Code 144 will become
inactive. Diagnostic Trouble Code 144 will not cause
the warning light to illuminate.
Diagnostic Trouble Code 144 may be caused by:
• Poor ground connections for the CMP or other
electronic components
• Wire harness shielding missing or incorrectly
installed on the engine harness
• Outside components that could induce voltage
signals
EDIT:
ewo1 beat me to it!!
Cam Revolution
Code.
light on.
signals
EDIT:
