Aaron H
$14,000 OBO
7.3 Power Stroke / Allison Tranny
Only 167k miles Runs STRONG
-Already Titled/registered as motorhome-not a commercial vehicle
Big change in Life-Priorities is the reason for selling. $20k Invested
-New brakes, brake lines
-New Tires all around
-Gutted and wired for new outlets, lighting, systems, Rear Mount Camera, etc. according to my design but could easily be added to since walls are not in. Wired for DC and 110 Outlets. Most 110 outlets have USB ports.
-Spray foam insulation to R14-21 value...Intended for fun even in the xtreme temps. Spray foam adds density and Sound Barrier.
-1" Foamular foamboard in floor with best-in-quality Advantech sub-floor
-Comes with ALL Major Components for completion except for some raw materials to build the inside HOWEVER YOU WANT!
INCLUDES:
-Hard wood flooring (not yet installed)
-Rovsun Mini-Split AC/Heater
-Generator
-2 Renogy Deep Cell Batteries
-Inverter , Battery charger, Fuse box / fuses, cables, etc.
-Toilet, bathroom sink, kitchen sink, water heater, water pump, all 3 tanks for fresh, grey, black water, plumbing/fittings, etc.
-Gas stove, Refrigerator
-All LED DC lights, outlets, etc Including new LED clearance/marker lamps outside installed
-And More - All Brand New in boxes as you see stacked in garage.
-Driver side windows All re-sealed. still need passenger side done. As you see it still needs work / touch ups on outside or start over with your own color schemes.
Title Free and Clear
FULL DISCLOSURE: When old flooring was removed there was significant rust, particularly around the wheel-well. The bad was all cut out around the wheel-well and rebuilt with new sheet metal and fiberglass patches. Entire floor sanded / wire brushed and treated with Chassis Saver. I still have enough Chassis Saver to treat the entire underside...just haven't gotten to it yet. If bus not sold right away I'll probably do it on the next really warm Saturday. Should be good for many more years.
THIS IS A PACKAGE DEAL - ALL OR NOTHING. WILL NOT NEGOTIATE ON PARTS.
Please message. Thanks for Looking!
INCLUDES:
-Generator
