ATrain-SKO
Between you and the mechanic you'll get it sorted out!
With my bus I've been playing with the trans air roof top unit and can't get it to kick on. I replaced the digital thermostat and chased down the wiring with no avail. Looks like I'm going to pull the unit (which was the original plan) but I wanted to try and get it going prior to removal. Ahead of pulling I've talked to another skoolie owner local to me and found where to source sheet metal to patch the roof and for my window deletes. One good thing is that after I remove the roof top unit the bus will fit through my 10' shop doors. Then I'll be able to work on it regardless of weather!
