Hooker-SKO
I have a 2002 Feightliner FS65 Thomas with Cummins 5.9 ISB. It got stuck in some wet mud one day. Next day went out to get it out and rocked it a bit and it just started to dig the rear wheels into a hole so I stopped and figured I'd have to wait til it dried out. While the engine was idling, it just shut off and wouldn't restart. I let it sit a few days for the grond to dry out. It never started, but would with an unleaded rag prime in the air box then shut off immediately. So I replaced the fuel filters. Both filters were bone dry when I took them off. I filled the new filters with fresh diesel. Cranked a bit, but it started and ran for about a full minute and shut off and will not start again.
I'm guessing the lift pump isn't getting fuel to the filters? The injection pump was obvisouly able to pull fuel out of the filters for it to start and run for a minute.
So does it seem to be a lift pump to everyone else too? Can it possibly be a fuel pump relay? Anyone know if it's an in tank or outside tank pump and where is it located? Where would the fuel pump relay be located?
It ran fantastic up until this day. I was also wondering if the rear end of the bus sitting much lower in the rear now that the rear wheels are in a hole would have anything to do with it? Maybe a weak lift pump? Guage shows 1/2 tank and I have no reason to believe it's wrong, but I did add 5 gallons of diesel to the 1/2 tank just in case, that might be why it wasn't picking up fuel.
