halfdime
Ok. I’ve done some research and some calculations on the rear end ratio.
The Bus
40’ Bus
DT466E - yet to determine High Torque model or not; serial # is covered or the motor is a transition year motor. Not in the spot I would expect to see a 2002 SN.
Allison MD3060 (6th still locker for now) Final drive 0.75:1 for the transmission as standard. 1st is 3.49 I believe but need to check my notes. It’s a close ration MD3060CR
Rear end 6.17:1 Dana Spicer 23080S, air suspension, air brakes.
11R22.5 tires (42.2” diameter)
Have not weighed it yet, but would guess it will be in the 23k range built with 6k in tow.
Also plan on adding an electric fan and removing the engine driven fan foe more HP.
The Plan
Drive the bus through the mountains with2 adults, 4 kids and a dog.
Pull a Subaru Ascent on a car hauler
The Questions
1. Has anyone got a similar setup with a 4.63 rear ended? Good for highway, how about start-ability?
I’ve run numbers and while the star-ability is not dramatically reduced from stock, it’s a number that lacks context and is a reference number.
2. How about traveling in the mountains? 20mph would be painful, but may be what it is. Any experience on what to expect here?
I realize that there are a lot of variables here, but looking for some advice ans experience.
The Bus
40’ Bus
The Plan
The Questions
