mrlupr
I am putting my project bus up for sale. For personal reasons I am not able to complete this project. It is about 70% done (depending on personal preferences).
The floor layout can still be easily modified. I am including nearly everything you would need to finish the project.
2004 International CE-200
Titled, registered, and insured as an RV in Texas.
170k miles, No rust
Transmission: Allison 2000 automatic 5-speed with overdrive.
Runs and drives perfectly.
Full tune up performed with zero miles driven. Including full synthetic motor oil change, coolant flush, oil filter, fuel filter, pre-fuel filter and intake air filter installed.
Two brand new deep cycle marine batteries.
Includes bonus additional 5 gal. bucket of full synthetic motor oil.
Electrical: The bus is outfitted for 50Amp shore power. Included is a 1000W 12V power converter. 115V and 12V circuits are available throughout the bus. There are multiple additional circuits available for expansion.
Plumbing is not complete. Most freshwater lines are installed and ready. Wastewater lines need to be finished.
Fully insulated with XPS insulation on top bottom and sides.
Pine tongue and groove boards for ceiling.
6 Brand new Hercules H-309 tires.
Set of 4 Centramatic Onboard Wheel Balancers.
Galanz 7.6 cu.ft. Retro Mini Refrigerator brand new.
Two (2) DOMETIC BRISK II 15000 BTU Polar White Air Conditioners brand new.
Two (2) Twin size Zinus 6 Inch Green Tea Memory Foam Mattresses brand new.
360-degree surveillance system and driving cameras with triple 10.1 inch security monitors. There are cameras on the left, right, front and two on the rear. The rear cameras are one for parking and the other for hitching a trailer. All cameras can record all the time.
Powermax PM4 100A 110V AC to 12V DC 100 Amp Power Converter with Built-in 4 Stage Smart Battery Charger.
BlueFire on-board Bluetooth ECM monitor 9-pin adapter for Motorhomes.
NEXIQ USB-Link™ 2: Bluetooth Edition. (Only used it to change the speed limit to 75.)
This bus comes with tons of extra accessories and equipment for you to finish the project, along with some key tools I’ve had to purchase along the way.
The following tools will be included in the sale. I changed all six tires myself with these very tools.
VEVOR set of tire mount demount tools including mounting bar, demounting bar, and bead keeper.
Esco 22 Ton Pin Style Jack Stand.
BIG RED TA92006 Torin Pneumatic 20 Ton Hydraulic Automatic Bottle Jack.
Neiko 20743A 3/4”-Inch Digital Torque Adapter, 150-750 ft-lb
XtremepowerUS Torque Wrench Labor Saving Lug Nut Wrench Torque Multiplier.
The following accessories and equipment will be included in the sale. Everything here is brand new unless otherwise stated.
Two (2) ICON HT648-ED 39 gal. Center End Drain Waste Holding Tanks with 3" Spigot and 4-Level Sensors. The original idea was one tank for gray water and one tank for black water.
Thetford Aqua-Magic Bravura Toilet with Hand Sprayer.
32” Insignia LED Fire TV.
Mustee Durastall 32 in. X 32 in. White Shower Stall.
CURT® - Class 5 Trailer Hitch with 2" Receiver Opening (16000/2400 Weight Capacity)
CURT® 55243 - T-Connector (4-Wire to 7-Wire Upgrade Kit)
SEAFLO Shower Sump Pump System.
2 Gallon Accumulator Expansion Tank with Wall Mount Bracket.
White Rectangle Wall Mount Hung Porcelain Ceramic Small Sink for the bathroom.
Single-Handle Swivel Spout Bathroom Sink Faucet with Pop-up Drain.
HOUZER A1722-7BS-1 Stainless Steel Sink for the kitchen.
Stainless Steel Kitchen Faucet, High Arc Single Level with Pull Down Sprayer
There are two new stoves because I changed my mind during the build. Kitchen counter holes have not yet been cut. The buyer can still change the equipment or layout.
• Flame King YSNHT600 2 Burner Built-In RV Cooktop Stove.
• 22″x20″ Built in Gas Cooktop 4 Burners Stainless Steel Stove with NG/LPG Conversion Kit
Two (2) Tradesman Underbody storage bins each are 36” wide with locks. (These boxes are used)
VALTERRA® - Double Rotating Waste Valve 3" Hub x 1-1/2" Hub x 3" Bayonet with Cap
CAMCO® - Tornado™ Rotary Tank Rinser Kit with Hose.
CAMCO® 43051 - Sidewinder™ 20' Black Plastic Folding Sewer Hose Support
CAMCO® 39625 - Revolution™ 20' Brown Sewer Kit
CAMCO® - TastePURE™ KDF/GAC 2.5 GPM Water Filter with 4" Hose
Mophorn RV Shore Power Extension Cord 25 FT 50 AMP Weatherproof Heavy Duty. (This item is used).
Six (6) new seatbelts
Overhead exterior vents
Multiple LED light fixtures.
24 in. x 80 in. Flush Hollow Core Unfinished Hardwood Interior Door Slab
Various outlets and cabling that were purchased for the RV and haven’t been used will be included with the sale.
You can see the engine video here.
https://streamable.com/leel5m
Located in Lubbock Texas
Asking $14,000 OBO
170k miles, No rust
Asking $14,000 OBO
