tomas-bluebird
Hello all, I have bus mentioned in headline with CAT C7 and Allison MD3060 with push button selector. Dash seem to be provided by Actia.
Problem is that some dials on my cluster are not working + I would like to see more information than I have available (cruise control set speed, engine oil temp, transmission temp, currently engaged gear and some more).
I was able to connect to J1587 my bus has via computer and writing simple python script starting sniffing data - I verified I am getting everything I need from engine, as I decoded myself or with help of C7 service manual. I was able to get even instantaneous fuel mpg which is imho going to be helpful too.
Now question #1: for my trans, I am able to decode both, selected (via push button) and engaged gear. Trans temp is funky though, I wasn’t able to get reliable info about turbine and oss rpm either. Does anyone have J1587 specs for MD3060?
Question #2: ODO miles are provided only via cluster - engine has something saved but the value is about 5mil and doesn’t seem to be reliable. I scanned whole log I got from 13 min drive and there is absolutely no info about miles in my range. I am also not getting any msg from cluster (which also why, not needed to anything). Anyone knows how to access this?
Whole idea is that I will implement custom screen style dash using N100 computer and scripts I have created so far. I can’t find service manual for my BlueBird anywhere, I see older up to 2003 which doesn’t have instrument cluster specs and newer 2008 which has updated dash and absolutely no info about J1587 as that year completely switched to J1939.
I also noticed that engine & bus has connected J1939, most likely for communication in between engine and trans, it might be under dash too but diag connector has J1587 pins only. Maybe I need to add other pins for J1939 but before I do so, I want to ask if anyone can help with J1587 route.
Thank you in advance!
(Attaching picmof dash for reference)
