2005 Freightliner FS65 Skoolie motor home HIGH TOP ONLY 160,882 miles
Bus was done for traveling to NASCAR Races. Bus has been to Moultre GA, pigeon forge TN twice - camped on river and deck was wonderful, Atlanta Ga for race weekend 2021,
Silver and black exterior with complete customer interior
Mercedes Benz Diesel engine
Allyson automatic transmission
22.5” tires with new Alcoa wheels
New batteries
Bus was originally used and purchased from Birmingham AL school system and maintained under fleet maintenance
Before construction began bus was taken to Big Moe near six flags over GA for a complete inspection. Replaced all rear end bushings, fasteners, replace air proportioning valve. Construction began once bus was returned from Big Moes in February 2020.
Rear deck was custom fabricated and installed by first class welding shop in Marietta, Ga. rear deck is 6’ off rear of bus with easy access from rear steps and grab bar.
Inside was completely gutted and inspected before build out, no rust was found. Interior walls are well insulated as some rear windows were removed, foam insulation installed and paneling installed on top.
Entry door and rear door at bathroom are completely custom fit to openings in bus where original doors were removed. Doors do not sag or drag and front door is tinted. Rv style lighting over rear and front door
Interior floor is brand new and installed with all appropriate trim
Walls have shiplap, with accent walls with reclaimed wood
Sofa is a triple recline electric and recliner for additional seating
Full size residential refrigerator and convection microwave combo. Residential stainless steel sink
Electric fire place with TV wall mount. Adjustable rv tv antenna
4 twin size bunk beds with wall mounted outlets and cable connections
Bathroom completely custom with tile shower and custom shower door, residential vanity, dometic toilet with blinds on rear of bus for privacy. Pocket door with 2 locks, linen closet with additional clothes closet. 45 gallon gray tank and 45 gallon black tank with 88 gallon fresh water tank. 10 gallon residential hot water heater. Plumbing manifold custom designed to turn on and off each valve if needed. Heavy duty 4 speed exhaust fan.
2 15,000 BTU air conditioners with heat strips
50 AMP service with 25 foot shore line cord
BRAND NEW ONAN 5500 watt gas generation with NEW 25 gallon gas tank
Bus was a complete labor of love and a family project. ONLY selling due to not traveling as much to races. Purchased house in Pigeon Forge and will not use bus as much as anticipated.
MUST SEE TO APPRECIATE
RUNS AND DRIVES GREAT
$79,950.00
New batteries
$79,950.00
