I need some help. The bus was gutted and rear AC and heater was disconnected. I removed the wiring and panel above cab. I checked that the bus started each time I removed a wire, but neglected to see if the dash AC and Heater worked each time. Never thought those would be connected into the panel above. I found in another post that removing the CR and CLR connections would stop the heater and AC. Does anyone know how I can rewrite these from the dash to get them to work again?
