TheForkInTheRoad
- Joined
- Dec 17, 2023
- Posts
- 49
Recently acquired 2008 Thomas Saf-T-Liner with Cat C7-210 and Allison 2500 PTS.
I bought it without doing my due diligence and have found issues with the fluids. Coolant was down by 6 gallons, Oil is over full and transmission fluid does not register on stick when hot.
I'd like to change the oil and filter - The bus says it has 169k. Bus came from Texas Dealer and was from a Texas school district. I have no service records.
Where does one find what type/weight oil should go into this engine and quantity?
I was thinking of taking an oil sample and having it analyzed but not sure if that is worth the money or not.
When the bus is started and idling it does not smoke. The engine oil is black and black can be and does not smell burnt or like diesel to me.
I am thinking an oil change no matter what should be done at least to get the oil level back to correct level. Perhaps after than and running it it will overfill again.. if so could that be due to diesel getting into the crankcase? If it were coolant wouldn't the oil be some other color that black?
I am a grasshopper with the thought of Skoolie conversion let alone anything diesel. So be kind
Any help advice, etc is much appreciated in advance.
