cadillackid
2500 PTS is a standard school bus transmission.. it is a wider ratio gearbox with lower end gears 1-3 for better take off and less stress on the engine / toreque converter during stop N go.. "PTS is Pupil Transport Series". your 4th gear will be 1:1 and your 5th gear will be 0.74:1 overdrive.. that unit is likely 4th gen and could be 6 speed programmed (6th would be 0.64:1)..
the onboard spin-on filters for the 1000 and 2000 series SAE transmissions are identical..
other than the gearing the 1000 and 2000 series are very similar..
the 1000 was initially released as a GMC-only transmission with a GMC bell / tail for the 2500/3500 series pickups with a duramaxx.. the 2000 series was released as the medium duty unit with an SAE3 (or SAE2) bell housing and tail housing..
interestingly enough GM used the SAE series 2000 transmisisons on their medium duty C4500/5500/6500 etc trucks with duramaxx or 8.1 gas.. yet still used the GMC bell 1000 series in their pickups..
its possible someone swapped a 1000HS into a bus ..the HS is a highway series which is kind of wierd for a school bus as it would be geared taller (1000's have a 0.71:1 5th gear and a 0.61:1 6th gear)... seems wierd to me unless the original trans died and they swapped in what they could get from a local shop.. or a local build shop used a 1000 case and installed the guts of a 2500 PTS in it.. (they arent supposed to do that but a non allison dealer might ).. if the yhad actually installed a 1000HS in place of a 2500 PTS, the TCM wouldve complained with ratio error codes and a check-trans light as the gears wouldnt match what the computer thinks they are..
