MikeDruhl
Greetings, I plan to answer this question for myself eventually but thought someone else might have solved it already? I have a 2009 Bluebird All American Handi-Bus with the Cat C7S. Cruise Control appeared to have no power, and the Tire Chain switch is grouped together on the right side of the dash console with the cruise control switch. Neither work and only the tire chains have a fuse by that name (tire chains). I can see one of two connectors have been removed on the fuse block so inserting a fuse won’t correct the power issue, at least to the chains. My theory is perhaps the chain and cruise control switches are both powered on the same fuse. Anyone have any ideas? I’ve tried looking in the under driver side fuse panel, in the panel outboard of the driver window, and on the dash lower left side. Even took a look in the relay panel on the front drivers side behind the windshield wiper door. I’m a bit stumped.
