Deadman06271
- Joined
- Dec 29, 2020
- Posts
- 5
FOR SALE - 36FT 2010 INTERNATIONAL SCOOL BUS BUILD
Your ad should include ALL of the following:
Price - 30K - OBO - All offers Heard.
Location - College Park MD 20740
Detailed description - Read Below.
Pertinent maintenance and condition information - Read Below.
Pictures - Sorry if order is Wonky, New to this upload format. - More Photos available upon request
I have a partially complete Skoolie/Camper Bus for sale 30K OBO - All Offers heard - Cash, ACH, or Certified Checks only - Title will not change hands in person until checks are verified by the Issuing Bank.
I am available to show the bus any week day after 5pm or any time on weekends with advance notice.
Will Deliver For Free within 75 Miles using Dealer Plates. -Open to longer distances W/Compensation. - Bus runs and Drives under its own power perfectly fine. - All mechanical systems and required lights work.
Mechanical info (The Bus itself)
Engine - International 7.6 maxxforce Turbo Diesel / DT466E
Transmission - Allison Automatic
Brakes - Electric Hydraulic With ABS/Traction Control! - NO AIR BRAKES
Parking brake - Electric hydraulic Driveshaft brake.
Tires - 6 Standard Road tires for bus - all appear in good condition and hold air.
Mirrors - All mirrors have electric heat for de-icing with a switch in cab. - bus has standard school mirrors including
hood mounted mirrors to see front bumper.
Diesel Coolant heater/Booster Pump - Bus is equipped with a Diesel fired coolant/block heater that is not currently
connected to the cooling system, all wiring, hoses, and connections are still included.
Camper/Build info.
Most of the Core parts for the Electrical/Plumbing/HVAC are already installed or come with the bus. There are also
boxes with various hardware and trim removed from the bus during the build process. Nearly Everything pictured
comes with the bus EXCEPT for the Milwaukee Tools, and my Weight Set.
Parts List
SOLAR - 10X - 300W[3kW] Monocrystalline Solar panels - Brand new - INSTALLED not wired - Panels are mounted
on Gas Struts/Hinges and can be raised to aim towards the sun for max efficiency.
HVAC System - Mitsubishi 220v AC/Heat Pump - INSTALLED - Mounted on Rear of bus. System Powers on and runs
using shore power. - Heat can also be provided by the Diesel Engine block heater if reconnected to allow heating using
less electricity.
WATER - NOT Installed
-2x 100 Gallon tanks (with Brackets /hardware for mounting to frame under floor.)
- 60PSI/5.5GPM water pump with 2gal accumulator.
-Propane Tankless Water heater (16L 4.2 GPM Capacity)
-Misc. Fittings & Valves For plumbing/ Draining tanks.
ELECTRICAL - Not installed or Wired.
-2x 22v 5.2kW Lithium battery modules (Tesla Battery Packs With custom BMS board installed & BMS Modules to
keep cells balanced.
-Victron Solar Charge controller
-Victron Automatic Low Voltage battery Disconnect (to protect Lithium Cells from Damage.)
-24v to 110V inverter
-24v to 220v inverter
DRIVER SAFETY - PARTLY INSTALLED.
-4 camera Dashcam/Blindspot/Backup camera system with 10" Display.
All 4 Cameras are mounted, Aimed, and Sealed to prevent leaks
The display wiring has pins for all 4 cameras to automatically take up the entire screen when requested, this
means that in reverse, the backup cam takes full Screen, same for left and right turns to cover blind spots and
prevent accidents. these settings can be adjusted for personal preference.
WINDOWS - INSTALLED.
ALL of the bus windows except for the Permanently mounted windows (Windshield, Rear Glass, and Door Glass)
have been completely removed, cleaned, and Resealed using Urethane Automotive Window Sealant.
An Emergency Exit window has been kept in the back area of the bus for safety.
Both Roof Exits are covered by the solar panels and are instead replaced with Tinted Lexan sheets to allow some
daylight in.
INSULATION - PARTIALLY COMPLETED.
The entire floor of the living area has been insulated with 2" XPS foam under 3/4" Plywood. There are no 2x4s under
the 3/4" plywood, only foam for maximum insulation
The walls and roof remain uninsulated but I have roughed in the studs and wall panels for spray/injection foam
insulation, Also mostly uninterrupted for minimal losses.
STORAGE
Mounted on the outside are multiple PVC tubes, meant to hold things like fishing poles and camp chairs or whatever
else you want really. - Can be easily removed and holes sealed.
Mounts for 2x 6-8 Foot folding tables on outside of bus as well.
LIGHTING/AWNING. - PARTIAL INSTALL.
-20' Custom Color matched Manual awning made by Carefree Colorado included - Awning has Aluminum Housing
and LED light upgrade built in. - (mounting hardware/support arms MISSING, can be ordered from Carefree)
-Multiple LED light bars mounted outside ABOVE doors, some not installed but included with bus.
SO MUCH More detail available in person OR By Phone/Video call, along with pictures and video of previous work completed to this point, showing condition before, during, and after.
Camper/Build info.
Parts List
less electricity.
daylight in.
STORAGE
