SWAShuttleGuy
Hey guys,
I have a 2011 E350 ECII Elkhart 24" shuttle bus with dual batteries on a sliding tray. Located on the passenger side behind a little battery door just past the double entry doors.
I was inspecting the batteries, they look good, only 2 years old, and noticed the power connections inside the battery box have some corrosion on them. The plan was to slide the tray out to allow more room to access the connections and clean them.
Here's the problem - the tray has sliders, bearings etc, and is mounted to a frame but I am unable to locate a release, cable, toggle, or whatever that would unlock the tray and allow it to slide out.
There are two lever type devices, one on each side, that appear to do something but there is no connection to them except where they are bolted to the tray frame. No cable, no spring, nothing that jumps out and screams this is a release.
Does anyone know where I should be looking to locate where the release is if what I'm seeing was a release but has failed?
