30 Amp Shore Power Cable - $25
Slapdash
Oct 28, 2021
193
New England
Hey Gang,
If you're at the beginning of a build, or you drove away with your bus still plugged in, here's a cheap replacement cable.
This 30A cable came off of a Palomino Stampede travel trailer. Powered everything up nicely before I removed it. Continuity tested post-removal and everything's on the up and up.
I will confirm length shortly, but believe it's 20 feet.
Happy to ship anywhere in the US at your expense (coming from eastern CT).
With shore power cables starting at $60-$100, this is a pretty good deal!
Thanks for looking!
Can't figure out how to edit my ad, but the cable is actually 25' long, not 20'.
The cable is 10/3, each wire inside is jacketed. Can use a dogbone to step down to a regular 3-prong 120V (provided you don't go over the rating; e.g. 30A at a campground, or 15 or 20A at home).
This was attached to an RV converter that worked fine. The only reason I am selling is because we wanted a slightly longer cable for space to keep our bus plugged in at home. I built a brand-new system and bought a new cable to go with that setup (if anyone's interested in that, let me know).
Hope this helps!
Yes- for 30 amp / 120 v all you need is hot/neutral/ground…
