The Rockwood Colony
- Joined
- Jul 16, 2017
- Posts
- 58
I am raising the roof on my bus as some of you know about 21 inches. I am extending the hat channels by lapping identical hat channels and then I'm using 18g 4x8 galvaneered steel to wrap the entire bus all of the way around all the way up to directly behind the driver seat. We are essentially doing a similar look to the "Transcendence" bus that Wess did. (GREAT DESIGN!)
We arent welding any of the hat channels or panels into place. Instead we are using 3m Panel Bonding Adhesive 08116 with rivets. The only thing we are welding are extensions to the ceiling channels that run linearly to the back of the bus that will extend the supports by the door and we are welding supports for the roofs transition angle which we are using square tubing for.
This is the help I need... HOW MUCH OF THIS ADHESIVE WILL I NEED TO BUY TO COVER ALL OF THIS???? It's kind of a big deal because the cheapest I can find it per tube is $40 so I don't want to get too much.. If you've ever used anything like this before and know how far each tube set goes, please feel free to give me some advice! Thanks so much!!!!!
PS. I had a similar thread up but my computer or my phone wont let me access it for some reason and I'm running out of time and nice weather so I just thought I'd post another. Sorry and thanks again!
