Hello! I am selling my bus Conversion. I am happy and excited to answer any questions. I am selling the bus for $68,000 OBO.*Sold as is.*
All pictures and videos here!
Gus the Struggle Bus
Login • Instagram
You can apply for financing easily with Hearth, a third party lender we use. You can request up to $100,000 (or if you’re paying with partial cash, simply request the amount needed for financing). It takes 3 minutes, does not affect your credit score, and immediately shows you your loan options and monthly payments. There you’ll see the rates and payment options.
Here’s the link so you can apply today: General financing from Tiny House Listings | Hearth
*Location of listing: Dallas TX, Pick up only*
*Square feet: 320 total*- front engine so around 263 sqft of living space*
*Length feet: 40 ft*
*Width feet: 8 ft*
*Height: 10 ft - 6ft 3inch head room on the inside*
*Year: 2002
*Make: International*
*Model: Dt466 flat nose front engine, allison transmission*
*Fuel type: diesel*
*Fuel tank capacity: not sure - fuel gauge*is broken and will need to be replaced. I downloaded an app to keep track and just kept and eye on it and a spare diesel*container handy*
*How many seat belts total: 5 - one for the driver seat and 4 for the couch*
*How many bedrooms/sleeping areas: 2- easily sleep 4 and plenty more room
What size mattresses: King and full or twin ( couch pulls out)*
*How many bathrooms: 1 and an outdoor shower,**nature's head composting toilet*
*Appliances: large sink, propane oven and 4 burner stove top, galanz fridge, mini split, tankless water heater, composting toilet, separate*portable propane heater that I use on the brick fireplace ( set up to eventually add a wood burning*stove) composting toilet, indoor huge shower, outdoor shower*
*Solar and off grid details:**
If off-grid, what's the solar setup (panels, inverter, charge controller, and battery type and aH)? *Please include brands and sizes4 300 watt renogy solar panels, combiner box mounted on roof, 6 12 volt lithium battle born batteries set up in parallel, midnite charge controller,* victron 12 volt/3000va/120amp inverter (can run lights, plugs and fridge no problem, should be plugged in to run mini split) , breaker box, 12 volt lighting, 120 plugs, led lighting, 50 amp shore power with a 30 amp converter cord, backup/front/ and side cameras with monitor*by drivers seat. extra side flood lights and motion sensored front door light.**Holding tanks:*100 gal fresh water and 100 gal grey water. with hose or hook up fill options. Drain on a grey water tank as well. Fresh tank is inside under the bed and a grey tank is mounted underneath directly under the shower.*
*Finishes: Natural earth tones, cedar plank tongue and groove ceiling, birch natural wood stain cabinets and walls, concrete feathering countertops*( black and grey), upper cabinets and plenty of storage, side storage on couch and bed with plugs inside, led lighting that changes colors along the bus walls, laguna table for couch and fold out table in living room, front engine cover, fireplace and storage, shoe storage right when you walk in, pull out couch that can make an L couch/U couch or larger bed. huge bathroom with sliding doors, huge slide out pantry, 3 total storage closets with lights, one bathroom closet with cat door cut out if they need to put a cat box in there. 2 skylights that open to roof, pull out mount for tv ( mount to move tv in bedroom and living room ) huge rooftop deck and extendable ladder, also has a hatch cover if you want to block the sun or make deck "bigger" two poles mounted on roof at the front of the bus for more tie down storage. Max air fan above kitchen, built in cup holders for driver/couch/and next to bed. Small reading clicks battery lights everywhere, storage under the bed that lifts up on both sides and is accessible*from the back door that opens. Pull out the bar under the deck so you can hang chairs from it or use it in multiple*ways. Two huge storage bins are mounted under the bus and the doors fold out with gas struts or you can hook them up with the chains and use them as outdoor table tops. U hooks mounted throughout the ceiling to hang a hanging chair or hammock inside as well. Kitchen counter on the left side moves and the side door still opens and has locks. Smoke alarm ( 3) and carbon monoxide alarm (1)
*Mini-split or another system for heat and air:*Pioneer® Diamante Series 12,000 BTU 20 SEER 115V Ductless Mini-Split Air Conditioner Heat Pump
*Shore power plug Amps: 50 amps but there is a 30 amp converter as well*
*Insulation: 2 inches of closed cell spray foam insulation on the ceiling and walls. Foam board on the floor with osb, then a layer of cork and then the industrial*grade laminate flooring*
*Towing capacity: Has two tow hooks under the back bumper but have not towed anything, should be able to tow a trailer and car but it will slow you down a little.
*How many miles are on it: 132,000- dash gauge*does not work but there is one a one of the wheels- a replacement gauge*or app to keep track will work!*
*How old are the tires and what are their condition? Orinional tires but still in good condition. Will need new ones especially if going to be driving on long trips.*
*Engine: Dt466**
*Transmission:allison transmission
Any questions or walk throughs you need please just ask!*
Login • Instagram
*Width feet: 8 ft*
*Year: 2002
*Fuel type: diesel*
*Engine: Dt466**
