cadillackid
wow how cool!! that rear deck will actually balance you out nicely!
plus you do have a lot of weight upfront.. 750 lb motor, 400 lb transmission.. the CAC guys are all about their 4 BT's. the one in his work truck is 160 HP and he isnt running an intercooler, its been that way for years and he has no issues.. makes me wonder if you need a charge cooler with 130 ponies.. or if you could get away with one of the compact ones at least. I also found some cool closed-loop air-water inter-coolers, where you locate a remote coil with a fan on it.. super compact under the hood and since the fluid can be cooled even when you are off the go-pedal you dont need a huge remote radiator for it.. under the hood the exchanger looks like a piece of 4x4 .. perfect for tight locations....
