Tango-SKO
Howdy Jack --- Eaton can pretty much engineer whatever you want. My new springs will be about half the originals spring rate of 4000 pounds before the overloads kick in (the old are WAY too stiff & bouncy) but will also drop the rear about two inches (it was about 3 inches high in the back). Of course I am guessing at all this, but hope it will ride softer and sit closer to level when all is said and done. I am also adding shocks to the rear which it never had. When I ordered the front springs, I had them compensate for the Cummins weight by upping them about 300 pounds. Who knows where it will all end up, but here's hoping for a little better ride. What can I say...I'm just not an airbag kinda' guy.
The window inserts will get riveted to the inside, then the flange mount windows go in with some seam sealer on the outside. Might add a couple of screws through the window frames into the outer skin to firm everything up. We'll see. I wish the HD windows were the flange mount type, I'd be all over them. So much easier to make weather tight.
Just picked up six new rims to go with the new rear axle. Dropping them off manana for sand blasting and primer. Still thinking through what their color scheme will be. Plaid? The the new rims will also fit the front axle but I need to make a couple of small spacers since the center pilot hole is bigger on the new rims than the old. The new rear spring mounts should be ready for pick up from my sheet metal shop on Friday and ready to weld on. Then...it's a couple of weeks before the rear springs arrive. Guess I'll be back on bodywork till then.
Onward!
Onward!
