Tango-SKO
Howdy All --- been a very busy Fall here and I'm just getting back to the Shorty. Just had replacements made for all the rusted away body spacers. The old were not even primed or painted, no idea why they lasted as long as they did. The new units will also get layered in fiberglass to prevent the water that will run into this area from the windows from wicking into the seam between them and the body (that's what caused the original problems). Once the glass is in place I will drill drain holes as per the original design.
Also found a very clean Toyota pilot's seat. Non-electric with plenty of manual adjustments including the beloved "lower Lumbar lump". May get it covered in Mercedes-style breathable leather if the price is not too steep, but for now it is in great shape. A friend is going to machine a super sturdy Lazy Susan base for it that will permit me to rotate it for use as a living room chair when docked.
And I am just about ready to start cutting away the old lower sheet metal. It will get replaced with new panels of Paint-Grip welded in place rather than screwed on. Any later body work should actually be simpler. One pic shows the angle iron "fence" I will run the steel cutting saw along. It will get tacked welded in a few places to secure it, then cut free and moved to the other side.
Here's a few pix...
Before...(the only one that survived removal)...
...After...
The set minus the one below...
...which actually fits!!!
The angle iron is only there as a fence to run the saw along. It will get tacked before the cut is made.
And finally...the new Pilot's Seat from an '02 Camry with less than 10k miles on it. (keeping it clean in my shop over the next few months will require a miracle in addition to the plastic).
Will post more as I progress, but right now the Winter looks like it will be a busy one. Hope everyone has a great Holiday Season.
Here's a few pix...
...After...
