Huge Progress!!! --- No...not really. You guessed it. My machine shop parts will once again be ready..."next week".
Meanwhile, back at the ranch house...
Had to something today, so I opted for some annoying, menial tasks. The first was a (needed) test fit of my radiator frame and new radiator brace (it was missing when I got the bus). Went fine, just had to make one of theose "two bolt" runs to the hardware store to get things in place.
Funny thing is...it looks and feels like actual progress. The front end has been naked for so long, having the bracket & rad in place makes it look much further along than it is. But, I'll just enjoy the moment.
Then there is the matter of having to shrink a bunch of holes. All of the existing screw holes for my upper rub rail are seriously wallowed out 5/16" affairs. Trouble is, I planned on riveting that chunk of metal in place using 1/4" steel rivets. Why not 5/16 you ask? Cause they are a whole nuther animal. For whatever reason, when you go over 1/4", they get crazy expensive and require a special hydro-pneumatic tool to install. I could rent a puller for about $150 a day, but then you have to buy a non refundable $580 head! Not gonna happen, especially since I already have a ton of the 1/4". SO here's how it goes...
Start with a wallowed 5/16 hole...
Cut down a quarter-inch fender washer to fit behind the old hole...
Fit the new, smaller hole in place with a spot weld hole prepared...
Weld that sucker in place...
Grind it flush..
Then hit it with some "Weld-Through Primer" just to keep it clean for a while.
Now...repeat the process 26 times and you are ready to rivet.
BTW...for whatever reason, only the forward of the two original holes seen were ever used. I think somebody screwed up at the factory.
ONWARD!
