BoggerBus
- Joined
- Mar 25, 2018
- Posts
- 34
just keep jacking it up higher it will eventually clear everything lol
Yeah you can have them retread your tires. Just don't run retreads on the steer tires.
Retread is not the same as regroove --
My steer tires, also Michelin's, also say regroovable onto the sidewalls...
How hard is it to find a 4x4? I have only seen a few.
Are they really unicorns?
How much of a price increase compared to similar 2wd?
The 4x4 buses I've seen on youtube and elsewhere ended up on their side. Turns out they are very good at getting you into a bad situation, maybe not so much at getting you out of them.
Just sayin' maybe trying to take a house cross country is asking too much.
Is it not more like how you would drive an army truck? Seems like in most cases you get out and scout out where you are going. With satellite photos and even drones with cameras, going some of the old desert mine roads would give a better idea of go, no go. My bus currently weighs about 15,000 lbs and have 9,000 winch and other bits, I have seen to many other stuck busses. I think I will try to move up to a 12,000 lb winch for this bus.
William
William
In my opinion, that's the way to do it. You don't want to get a vehicle that big, stuck, so taking a moment to walk it through is wise.
If anyone is curious, I'm building a 4x4 bus. Projected weight of 13,000lbs when all is said and done. Dana 60 front, NP205, Dana 80 or 11.5AAM rear, probably sticking with 4.56 gears: https://www.instagram.com/thatbuschoseme/ The bus is basically designed with traversing Ontario, Quebec, and BC's forest service roads/abandoned logging trails, in mind.
I'd like see it, but I don't do Instagram. Do you have an idea of the conversion cost?
