5.9 at545
HA are you an old HVAC guy?
"boilers are always easier to fix thanA/C..."
id rather fix A/C than a boiler.. or at least rather than troubleshooting flow issues which were often times at the root of boiler failures.. the boiler itself was easy but serious issues in hydronics - much tougher to shoot trouble in than even the electronic controls of a building..
How do i find starter killer relay? I have smaller e450 with same issue i never found key but i wired straight from battery and starter and in position on i could press button and van starts but never out of ��.how do i trace this? ��
Somehow i cut off buzzer one by one so far bus starts.also whats this warning sign on pic
Clean your strainers make sure the hwp's are running and your boilers are not off on a safety pneumatic air available ( unless your building has Belimos) and you are golden....
Personally have gone from air to hybrids to drives and ddc . When retirement comes this year gonna get a job programming sprinkler timers:biggrin:
How it comes that coolant rusted color and feels like water lol.i googled hard but didnt find wheres heater access front one to flush it inside.ive cut rear one and didnt loop with middle one coz of coolant .
Also both trans and engine looks like fluids werent changed in a long time coz rust took over aesthetically.
Found a warning code 268 or 278 lul
How do i trust school guys anymore with "excellent condition" lmao
Im dead😆
I flushed my entire cooling system, including heaters, by using two bottles of radiator cleaning additive. The radiator cleaner is designed for 3 or 4 gallon systems, and since my cooling system is 7 gallons it requires 2 bottles to have the proper cleaning strength. It will also clean your heaters internally.
This is something you're going to have to do after you get your bus running since this cleaning will require bringing the engine up to operating temperature.
Thank u Robin,i have problem :new water wont suck in system.i filled out bottle and it doesnt go further.what it could be.i tried run bus with heaters for 3 min .still the same.
There are similarities between the Dodge pickup engines and bus engines, but trusting Dodge information can get you in trouble at times.
I like to park on a steep hill with the radiator cap being at the highest point and then attempt to fill the cooling system completely. You'd likely have to run the engine for 15 or 20 minutes to warm it up properly.
No boiler rodding here.
Controls guy
That would make a boiler easier to work on than AC until your pipefitter buddy/boiler installer had them all running in hand just fine until the control man wired them master and slave (20 seperate buildings that the buddy ran all the conduit in the ditch between the building for the control man) and nothing would work and everyone's hollering at the boiler installer to get them back on line?
I know a few control men that would beg to differ on which ones easier to diagnose.
I went to all the boilers disconnected the 4-20 on all but one to get them fired But it ended up being the heat net manufacturers fault because they programmed them for lonworks and we were using bac net even though we bought them to used with bac net.
I know you will probably say it's cause I didn't have you and you could of looked at the circuit boards and seen it?
Just giving you a hard time. CONTROL MAN.
Take care
No, you misunderstood, I am a Controls guy.
We hang with other Controls guys.
Anything will run in hand and it will stay that way if you have a fitter doing your networking from down in the the ditch and he does not know the difference between Bacnet and LonWorks.
Call the Controls guy next time and He will hook you up.
Still ain't and never will be the control guy with the computer but it's all bacnet here and the suppliers still want to send mod bus and lonworks **** that don't quite work with bacnet.
Have a good weekend
That way filling up thru thermostat hole made my day.freakin rusted **** spit off.
besides that found sprinkling injector fuel line and small exhaust smoke :popcorn:
Does your bus have the trans cooler from the radiator?
"I like to park on a steep hill with the radiator cap being at the highest point and then attempt to fill the cooling system completely. You'd likely have to run the engine for 15 or 20 minutes to warm it up properly."
My 1991 T/C 2000 5.9 AT 245 has a 1/4" hard plastic line that starts at the transmission cooler runs up by the radiator filler cap with a valve at the end. The book gives a process where you add coolant and vent this line into the radiator a few times to get all of the air bubbles out of the system.
Hope this works for you too!
It seems you are not short on hills though..
Joe
