AzironaZack
1991 International 3700 Short Bus
Hey there, folks! I've got a 1991 International 3700 based short school bus with a 7.3 IDI, original injection pump, non-wastegated Banks Turbo, and intercooler. This bus is an RV for me and my wife.
I am having trouble with overheating.
The radiator, thermostat, fan, and viscous clutch are all new in the last couple years. The radiator shroud is in great shape and fits the fan well.
I recently swapped the AT545 transmission for an Allison 1000 six speed. I have 4.44 gears in the rear (originally had 5.38 ratio).
On a drive up Mt Lemmon (local mountain for us in Tucson) on a 105 degree day the coolant temperature light and alarm came on around halfway up. The coolant temperature was 210 degrees (according to the tiny, old gauge on the dash) and the transmission sump temperature was 210. I pulled off and allowed the bus to idle cool in the shade, but it still is disconcerting.
The radiator is a Northern Radiator 232124, which is brass and truly enormous (31 x 26 1/8 x 2 1/16 (4 Row)). The radiator cools both the engine and the transmission fluid.
I'm hoping folks can provide some advice on the overheating.
I suspect the new gearing with the six speed has dropped my engine speed to the point where it's affecting the cooling capacity of the fan. This is just a guess.
When I installed the intercooler I cranked up the injection pump fuel screw. I'm making great power now, but I wonder if this is part of the problem too.
I'm curious what the experts in here think.
Would it be worthwhile to switch to a big electric fan set up? What about switching back to the 5.38 gears in the rear end? Swapping to the higher gears would make my engine speed higher for a given road speed. Right now I seldom see sixth gear, but with the higher ratio I'd probably see sixth more regularly.
What do you think? Thanks!
