PorchDog
1996 Bluebird, DT466 Mech. Spicer 5 Spd. 6 window
My 7 window 1995 Bus has a mechanical DT466 rated at 210 HP with an Allison MD3060 and 6th gear is NOT unlocked.
It currently has 10R tires, but I think I will change to 11R some day. It came from the factory with a 6.14 rear axle ratio.
My plan is to live without 6th gear-- but change the rear axle ratio.
Per the Spicer gear calculator--- using 41.75 inch diameter tires--and going to a 5.38 rear axle (which is a pretty big change) I get--
4th gear (1.00) 2350 RPM equates to 54.28 MPH
5th gear (0.75) 2000 RPM equates to 61.59 MPH.
60 to 65 MPH is about my normal speed. Mostly 62 or so.
Will I be happy with the 5.38? My only other choice would be 5.63. This is a pretty pricey undertaking-- so trying not to screw it up.
